Author Topic: Removing oil filter housing?  (Read 1383 times)
« on: 23 October 2007, 23:04:44 »
Hi Guys,
How does the entire oil filter housing come off, on later models? Looks like the whole housing has to come off, to reach the oil cooler pipe nuts...
HI2DVY
  • Deepest Darkest, Scotland
Re: Removing oil filter housing?
« Reply #1 on: 24 October 2007, 00:00:20 »
Remove the filter cover cap (24mm socket). This should only have been tightened to 15Nm so should come off easily - although be warned, they can sometimes be really tight and a nightmare to get off. Once the cover is off, the paper filter should come out with it. Inside the filter housing is a hollow bolt. This holds the housing to the block. Take this out and the jobs a goodun!  :y
some day.....
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 24 October 2007, 16:56:37 »
Sorted, spot on :y
