Author Topic: breather from sump???  (Read 4059 times)
holey head
  • leeds uk
  • i'm a new dad
« on: 22 October 2007, 18:56:33 »
hi all how do i get the metal breather that connects to the sump off so i can clean it. the big metal pipe!
ouch my head hurts! i'll try and remember to wear my helmet next time i'm out on the quad!
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: breather from sump???
« Reply #1 on: 22 October 2007, 21:30:16 »
If it is the same as a 2.2 then it is held on by 2 bolts into the sump and the rubber hose at the top connecting it to the cam cover.
Trade club card holder
Code scanner available
Craig_R
  • Watford
« Reply #2 on: 22 October 2007, 21:35:14 »
also dont forget you will need a new gasket, i am sure it has one but i could be wrong i have been more than once :)
Mod's
[To be Fitted]Reverse Sensors
alexandjen
  • The Silver Surfer
« Reply #3 on: 22 October 2007, 21:37:23 »
Mine has a gasket but I reused it with a bead of sealant as it was in good condition  :y
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #4 on: 22 October 2007, 23:02:02 »
The gasket on this pipe is metal and only costs pennies - you'll find loads of mayo inside but don't worry it's quite normal.  :y
« Reply #5 on: 22 October 2007, 23:11:43 »
I've never replaced this gasket, but if it's only pennies then you may as well...
the pipe may take a lot of cleaning!
It's held onto the block (not the sump) by 2 x 13mm bolts.
ians
  • Reading
« Reply #6 on: 23 October 2007, 09:52:30 »
I never figured out how to remove that pipe.  I'm assuming its from underneath..?
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #7 on: 23 October 2007, 12:42:06 »
Different on a V6 to a 4 pot.
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #8 on: 23 October 2007, 12:44:46 »
It is the same, just a little more awkward to get at on a 2.0 ltr.
Follow the instructions for the 2.2 under 'Maintenance Guides'.
I like red cars
ians
  • Reading
« Reply #9 on: 23 October 2007, 15:01:47 »
AA - I used to have a 4 pot which is what I was referring to.   That pipe always looked like it descended into the depths of hell but I never investigated from underneath.
Chopsdad
  • Keep it clean!
« Reply #10 on: 23 October 2007, 19:55:20 »
The pipe is only 15-18" long and fit's on top of the sump.  I reused the old gasket last time as Vx were out of stock and it's never leaked, but I'll change it next time.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #11 on: 24 October 2007, 10:19:58 »
More diificult to get at on a 2.0ltr from the top, but not impossible if you've got rubber arms.
I like red cars
Craig_R
  • Watford
« Reply #12 on: 24 October 2007, 10:44:39 »
its very hard to get out from the top or bottom.
I find its quicker to just remove the exhaust manifold heat sheld and the secondary air injector pipes than messing about bursing and scratching your arms
Mod's
holey head
  • leeds uk
  • i'm a new dad
« Reply #13 on: 24 October 2007, 18:25:24 »
cheers all i will be trying that at the weekend as i'm really busy at work!
VX1
  • Reading, Berkshire
« Reply #14 on: 24 October 2007, 19:14:12 »
Now just to clarify for the 2.0ltr crankcase breather pipe.
You can get to it by putting the car on a set of car ramps.
From underneath the car remove the underbelly cover ( if you have one) and undo the two 13mm bolts.
Then remove, (hoping that you have removed the hose from the cam cover), Once you have done this you can clean the breather. Spray carb cleaner down the tube and with a piece of cloth with wire wrapped around, pull the cloth through. If the tube is clogged then you will need to dig the crud out. The refitting is the same as removal but remembering to smear sealant around the bottom of the tube.
Thats how you remove and clean the crankcase breather. This tube is easy accessable from under the car, much quicker than removing the exhaust manifold heat shield and secondry air pipes etc.
Vx Trade club card holder
Halfords trade card holder
Page created in 0.027 seconds with 21 queries.
