Author Topic: Rear bumper removal  (Read 4633 times)
amba
  • Medway towns
    • German V6
Rear bumper removal
« on: 21 October 2007, 09:19:28 »
Some s.... decided to run into the rear of my elite saloon last night in car park and has creased the chrome rear bumper trim and slightly turned up the black bumper .The painted panel skirt is fine.Can you remove the rear bumper and just replace those two parts or is it a total new rear section?If the sections can be replaced would it be wise buying a good second hand rear unit complete and salvaging the parts??also how do you remove and repace the bumper unit..is there a "how to "
VX1
  • Reading, Berkshire
Re: Rear bumper removal
« Reply #1 on: 21 October 2007, 15:31:20 »
Take alook here. This will tell you how to remove.
http://www.omegaowners.com/forum/YaBB.pl?num=1192976314
Vx Trade club card holder
Halfords trade card holder
amba
  • Medway towns
    • German V6
« Reply #2 on: 21 October 2007, 15:43:39 »
Thanks vauxhallomega 1..that makes perfect sense and looks quite straight forward..am i correct in saying that you can remove just the bumper and chrome trim without removing the bottom painetd skirt ??if so as would seem to be what the guide is suggesting can you buy the bumper with chrome strips or are these usual GM lottery winners only and second hand is the way to go ?
VX1
« Reply #3 on: 21 October 2007, 15:49:37 »
The bottom painted skirt of the bumper is part of the bumper and cannot be removed Hence why they are so expensive.
You can replace the chrome trim in three sections they are seperate strips. How ever if the bottom part of the bumper is damaged then I would suggest replacing with a good secondhand one. Two reason's.....
1) It's much cheaper to replace secondhand than buying new. (this will result in hundreds of pounds to buy and spray)
2) If you are lucky enough you may just be able to find the right bumper in the right colour and in perfect condition.
HTH Paul :y
« Last Edit: 21 October 2007, 15:51:43 by vauxhallomega1 »
amba
  • Medway towns
    • German V6
« Reply #4 on: 21 October 2007, 15:54:35 »
Thanks Paul..
It is only the centre piece of the chrome trim that is dented and a very small crease in the black bumper just above number plate light.the painted skirt is un damaged so will look around for a decent rear bumper in parts or fleabay and take your guide as to removing and replacing.thanks again...andrew
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #5 on: 21 October 2007, 15:57:17 »
I take it this removal process differs for facelift models?
Code scanner available
VX1
« Reply #6 on: 21 October 2007, 16:04:52 »
If it's just the chrome trim that is dented then it may be worth while replacing the trim? The small dent above the number plate is nothing to worry about, just replace the trim. The part number is.........
Moulding, Rear Bumper Panel, RH, Chrome 90509528
Moulding, Rear, Bumper Panel, LH, Chrome 90509532
Moulding, Rear, Bumper Panel,Centre, Chrome 90509530
VX1
« Reply #7 on: 21 October 2007, 16:06:20 »
From what I can remember the process IS the same.
amba
  • Medway towns
    • German V6
« Reply #8 on: 21 October 2007, 16:09:37 »
Thanks Paul for part numbers ..will ring local crooks in morning for a good laugh to start the week !!!on closer inspection it looks like a tow ball has gone plumb centre into rear bumper and has left perfect half circle in center chrome trim and bumper moulding..so think might be more than just chrome trim unless I can knock or push out dent in bumper moulding..will have a closer look in morning as just off to watch Brazilian GP.
« Reply #9 on: 21 October 2007, 16:16:06 »
I replaced my centre chrome/stainless trim shortly after buying my car about 4 years ago & IIRC it was about £20 then. Plastic bumpers sometimes respond to a bit of heat to 'bend them straight' if they're not to creased - hair dryer or boiling water.
VX1
« Reply #10 on: 21 October 2007, 16:31:47 »
Thas true. I called one of the dealers here and got a quote for £25 inc so not gone up by much in 4 years. Makes a change though done it ;D
Dazzler
  • Haverhill, Suffolk
« Reply #11 on: 21 October 2007, 19:49:47 »
How does the chrome sections unclip from the bumper, is ther a secret way of doing this????
« Reply #12 on: 21 October 2007, 19:52:55 »
Err? Can't remember :-[ but it was very obvious when it was all on my front lawn/patch of moss. I think it was the painted section that held it in place.
Dazzler
« Reply #13 on: 21 October 2007, 19:56:34 »
So do you have to remove the bumper first before you can replace the trim??
I was hoping it could be done in situ ::)
amba
  • Medway towns
    • German V6
« Reply #14 on: 21 October 2007, 20:27:48 »
sound like it is quite complicated..looks like the chrome trims clip between the black bumper and the painted bit,so will require the whole thing to be taken off then
