Author Topic: Coolant coming out of header tank...  (Read 1459 times)
damon80
  • Wigan
« on: 25 October 2007, 21:15:33 »
Hello again folks...
After a run round the city centre today, when I parked up I decided to check under the bonnet with the engine on tickover (to listen to see if the hissing noise was any worse - as per my other thread).
Anyway, for some reason  :-[ I decided to take the cap off the coolant header tank (slowly I may add!), and coolant came shooting out of it!  :o  Anyway, I obviously put the cap back on sharpish...
Is this normal?  It's never happened on any other motors I've owned?
I'm getting a bit panicky now - could this be a sign that the HG is on it's way out??  :'(
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Coolant coming out of header tank...
« Reply #1 on: 25 October 2007, 21:17:11 »
I would think that is normal, as the coolant pressurises when hot.
I like red cars
damon80
  • Wigan
« Reply #2 on: 25 October 2007, 21:21:52 »
Phew - ta for that!
It's just that I've already experienced wallet-crushing HG failure in my last motor recently, so I'm a little bit on edge...
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 25 October 2007, 23:02:05 »
Every car I have had did this if the engine was still hot..... at one time it used to say on top of the caps don't undo until cool.. so I would say that this was right. :y :y
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #4 on: 26 October 2007, 21:54:45 »
Removing the header tank cap when the engine is hot is potentially dangerous. Pressurised coolant has a much increased boiling point, and has the potential to 'boil' immediately the pressure is released, with exactly the result which you experienced. You were lucky not to get scalded!
