Author Topic: dash bulb types/names  (Read 1393 times)
gstylebaby
  • stockport
« on: 27 October 2007, 17:51:35 »
Hi fellas quick 1 for you does anybody know the type/name of the dash bulbs i want to change them to leds and want to make sure i get the right one's also are they the same in the switchs (heated rear window etc) as the dash bulbs?
Mick_600
  • Warrington, Cheshire
Re: dash bulb types/names
« Reply #1 on: 27 October 2007, 19:45:40 »
Hi, assuming you mean the ones in the instrument cluster.
They are the same push type as now fitted to sidelights/ high level brake lights etc. This is a link to the type of bulb fitment http://cgi.ebay.co.uk/T10-501-W5W-SIDELIGHT-BULBS-BLUE-WEDGE-BLUE-SideMarker_W0QQitemZ260174218233QQihZ016QQcategoryZ72235QQssPageNameZWDVWQQrdZ1QQcmdZViewItem .
They seem to be referred to as 501 type.
However, I say type of fitment as although sidelight bulbs will fit, they are 5 watt and the instrument ones are lower, I think either 1.2 watt or 2 watt .... when I did mine the writing had mostly burnt off buthere was a 2 in there somewhere. If you put 5 watt ones in, I reckon you'll need to turn the dimmer down making the clock etc harder to see. I know because I had to put in 5 watt ones to replace bust ones and I couldn't get the right ones.
From memory I think there are 5 bulbs in the instrument cluster.
Cheers
Mike
