Author Topic: Hot or Cold  (Read 1839 times)
amba
  • Medway towns
    • German V6
Hot or Cold
« on: 28 October 2007, 09:59:21 »
Just wanted to see what others experienced with the temperature control within megas.Mine has climate control and all works as it should...climate on cold gives very cold air flow measured at 7-8 degrees at air vents..when turned up to high car gets nicely hot..trouble is the temoperatures in between..you are either very hot or cold despite setting climate to 22 ish and running on auto on climate ..if temerature is increased to say 26/27 still no noticable difference...is this a fault HBV as loose no coolant and do get hot or cold..just very little medium
Re: Hot or Cold
« Reply #1 on: 28 October 2007, 14:26:30 »
Sampling fan working ok?
amba
  • Medway towns
    • German V6
Re: Hot or Cold
« Reply #2 on: 28 October 2007, 17:07:17 »
TB...What is the sampling fan..sounds like something from a "cake factory "?????
hotel21
  • The Kingdom of Fife
Re: Hot or Cold
« Reply #3 on: 28 October 2007, 17:37:33 »
Chck between the climate guages.  There is a small triangular vent which has a fan within which samples the cabin air to read temp and adjust heater output automatically.
Place a paper tissue over it when all running and it should lightly 'stick' over the vent.
If not, its not working......   :(
amba
  • Medway towns
    • German V6
Re: Hot or Cold
« Reply #4 on: 28 October 2007, 19:10:34 »
Thanks Broocie..will have a look in morning when stopped raining..hope your week down south was ok..radiator all fixed and cured problem.thanks ..andrew
