Author Topic: can you help me make a decision please.....  (Read 4927 times)
Re: can you help me make a decision please.....
« Reply #15 on: 14 October 2007, 22:30:22 »
:-X
Only slight risk with an AR25 is that there are likely to be quite a few knackered ones around. Definately try and find one from a 2.0 not a V6, I'd say.
And do NOT get one from a TD, as it will be worn out.
« Last Edit: 14 October 2007, 22:34:05 by TheBoy »
Marie
    • 2ltr LPG Estate
« Reply #16 on: 14 October 2007, 22:32:53 »
sorry TD? defo going to shop around but where is the best place to start?
« Reply #17 on: 14 October 2007, 22:33:43 »
Sorry, 2.5 Turbo Diesel.  It wrecks AR25s in 100 - 120k....
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #18 on: 14 October 2007, 22:35:54 »
try this for a starting place. :y
Item number: 260169714197
Jaguar XJ6
ians
  • Reading
« Reply #19 on: 14 October 2007, 23:27:33 »
Marie,
Just a thought.  When you changed the fluid the last time, did you top it up with the engine running?  If not, the level will now be significantly too low and would be causing problems.
Marie
    • 2ltr LPG Estate
« Reply #20 on: 15 October 2007, 12:01:39 »
yes i did watch the garage run her warm checking the levels. just wondering whether they might have put the wrong grade oil in? is this possible and would it have these effects?
this fault only happens on reverse. once warm you have no hope of getting it into reverse even when shes cold its a snails pace and as i said before you have to power down and even then sometimes that wont work ether.
the gear box will travel through all the other gears ok. is there anything i could try before replacing it. or ?
ians
  • Reading
« Reply #21 on: 15 October 2007, 12:12:08 »
TBH I think that's unlikely unless they are real numpties.   Dex3 is pretty much standard ATF.
sassanach
  • trowbridge
« Reply #22 on: 28 October 2007, 22:29:54 »
did you ever bring this to a conclusion?
