Author Topic: V6 crank sensor location  (Read 1925 times)
retro_al
« on: 28 October 2007, 10:41:15 »
Any idea on were is located? ive looked around the front pulleys but cant see it,its pissing down so ive give up :'(
any help would be great  ;)
saintnick
  • Portsmouth Hampshire
Re: V6 crank sensor location
« Reply #1 on: 28 October 2007, 10:44:01 »
You will find the little bugger right next to the oil filter, held in by one torx bolt (E8 i think)
and it plugs in at the rear of the plenum, where the wiring harness ends, just under the passenger side wiper arm. Take care when refitting to make sure wiring doesnt touch any hot bits!! :y
Hope this helps
« Last Edit: 28 October 2007, 10:45:06 by saintnick »
If It aint broke....Lets just dismantle it anyway!
« Reply #2 on: 28 October 2007, 10:46:14 »
yep, passenger side... get underneath the car, with you feet facing out of the car look under where the oil filter is. Its located underneath the oil filter and you will see a silver foil wrapped cable leading down to it.
« Reply #3 on: 28 October 2007, 12:50:02 »
Your thought proccess was far too logical for an Omega! ;)  ;)  :y
retro_al
« Reply #4 on: 28 October 2007, 15:24:00 »
Cheers lads :) :y
hotel21
  • The Kingdom of Fife
« Reply #5 on: 28 October 2007, 16:38:05 »
Posted up a pic of location here
retro_al
« Reply #6 on: 29 October 2007, 15:32:21 »
Thanks ive found it and taken it out at the oil filter end,but i cant seem to find the other end  ;Dplease tell me i dont have to take the window wiper motor out again :(
hotel21
« Reply #7 on: 29 October 2007, 15:45:00 »
You have PM...
Also heres a pic of the rear of the engine....
http://images.omegaowners.com/images/guides/v6_engine_pics/IMG_0025.jpg
Sensor is the smaller connector, left of centre near the lifting eye thing, close to the breather pipes...
retro_al
« Reply #8 on: 29 October 2007, 16:31:52 »
Thanks i got it :)still hesitating tho  :-[ when i took the old one out there was lots of oil on it,is that normal?
You have PM...
