Author Topic: Simple cure for faulty key fob.  (Read 1772 times)
shyboy
  • Southport, merseyside.
    • Mazda 6
« on: 28 October 2007, 10:44:49 »
I've just 'repaired' my third faulty key fob at no cost whatsoever.
I took one to my local excellent Motor Spares shop,( not a factor), to replace the battery and was told the fob was damaged inside, but that the battery was OK. The battery is secured in a plastic socket and this is in turn supported by thin metal contact 'tags' joining it to the miniature circuitry board in the base of the key body. One of these had broken, (the same one in all three cases) which allowed the battery holder to spring upwards only slightly from its proper positon, thus opening the gap and destroying the contact between the battery and the circuitry. Soldering was suggested as a solution but i reckoned heat in this area could destroy the tiny components and was not an option without specialised equipment.
The solution was simple. I cut out sufficient tiny (about 1cm. square) pieces of thin card (one piece of thicker card would do the job just as well I'm sure) and placed them carefully in position in the base of the holder so that when the case was reassembled the battery was pressed back into its proper position.
Result- Key fobs working perfectly again with no suggestion of inconsistent operation and, of course, a little more money saved to pour into the tank.
A very simple cure, which I hope might be of use to somebody.
Bill
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Simple cure for faulty key fob.
« Reply #1 on: 28 October 2007, 12:00:57 »
Providing that you use a decent electric temperature controlled soldering iron & do not leave the bit in contact with the solder joint for more time than necessary you will not damage anything
On no account use a gas powered iron or attempt resoldering unless you are competant with electronics otherwise you are courting additional problems
IW
shyboy
    • Mazda 6
« Reply #2 on: 28 October 2007, 12:18:26 »
On no account use a gas powered iron [/u]or attempt resoldering unless you are competant with electronics otherwise you are courting additional problems
IW
Thanks IW. I never seem to be able to make soldering joints quickly enough even on bigger items, and so come into the category of an incompetent I'm afraid. :-[
Regards,
Bill
paulstmungo
  • Central Scotland
« Reply #3 on: 29 October 2007, 15:33:07 »
God only knows what the dealer would charge for a new key fob.
Ive fixed both mine with a touch of heat from the soldering iron, both failed on the boot release button which comes awat from the circuit board really easily.
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #4 on: 29 October 2007, 16:33:11 »
Ours is still running with that fix provided FREE by the parts dept of our local VX dealer as was maybe five years ago!
