Author Topic: Fuse for heated seats  (Read 1771 times)
ians
  • Reading
« on: 29 October 2007, 14:57:13 »
Can someone advise which fuse it is?  Seems that neither driver nor passenger seat heaters are working in my Elite.
Cheers
Ian
hotel21
  • The Kingdom of Fife
ians
  • Reading
Re: Fuse for heated seats
« Reply #2 on: 29 October 2007, 15:07:30 »
http://www.omegaowners.com/forum/YaBB.pl?num=1161602008
Even better - now marked as a favourite :y
However it looks like that fuse
14-30A Power steering, cigarette lighter, heated front seats, electrically operated rear window blind, air circulation system, electric air conditioning, heated rear window
would take out a load of other stuff which I would have noticed, not least the power steering.
Any suggestions of what might cause both seat heaters to stop other than both elements to fail?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #3 on: 29 October 2007, 18:26:45 »
I think there's a relay in the circuit, if that's gone they won't power up.
TuBy's new whipping boy.
« Reply #4 on: 29 October 2007, 19:13:34 »
......I think there's a relay in the circuit, if that's gone they won't power up.
Purely from memory - (hope I can do better than with the wipers! :-? I'm at work & Mr Haynes excellent manual is at home ;) ) I don't think the fronts have a relay and are wired direct from the switch. The rears use an ignition latched relay so they don't get left on for ever.
I'd check to see if there a voltage to the seats first, easiest thing to check, a good chance that both seat heaters are goosed if their fuse is OK
« Reply #5 on: 29 October 2007, 21:48:02 »
Most likely to be the heater pads  :'(, but check for power to seats to confirm (and be careful of the pretensioners!
