Pages: 1 ... 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 ... 33   Go Down
Author Topic: Project Tractor engine swap  (Read 88492 times)
Re: Project Tractor engine swap
« Reply #240 on: 26 August 2007, 21:52:09 »
I know naff-all about diesels .. but some google searching has found this :
on about diesel hummers ....
We talked to a tech at Stanadyne. He said too many tech's change injector pumps when the problem is really the injector itself. If the injector itself is bad it won't always show up in the ODB II codes. The tech recommended we put the motor back together and find 4 injectors off of a truck that is running Ok and swap out one bank at a time to see if this fixes the "running rough/misfire" problem before tearing into the motor further.
Got the truck together last night; except for setting the timing more accurately, seems to run quite well with 4 new injectors in, rather than putting in an injector pump and who knows what else. Guess it was the injectors all along
and on a golf :
Possible Symptoms
    * Loss of Power at high Engine Speeds
    * Engine difficult to Start
Possible Causes
    * Start of Injection Timing Regulation not OK
    * Injection Pump Control Range blocked/dirty (e.g. by Metal Particles)
    * Engine has stalled / ran out of Fuel recently
    * Wiring/Connectors from/to Injection Valve (N108) faulty
Possible Solutions
    * Check/Adjust Injection Start
    * Check Fuel Supply
    * Check/Replace Fuse(s)
    * Check/Repair Wiring/Connectors from/to Injection Valve (N108)
another site .. not sure which marque .. talks about "pump advance/retard stuck in a fixed position"
probably you have already considered all these points .. just trying to throw ideas in .. :(  good luck
« Reply #241 on: 26 August 2007, 21:55:46 »
Sorry......know the basics...but the prob you have TB i dont know....but question? coz im lost on the thread....is the replacement lump on the orig ecu.....or have you changed it? for the one for the donor engine....coz how i see it...with the probs your having....either engine is fubared and seller is telling porkies.....or ecu is incorect  :-/
Running my original ECU on the donor engine.
« Reply #242 on: 26 August 2007, 21:56:48 »
and on a golf :
Possible Symptoms
Possible Causes
Possible Solutions
    * Check Fuel Supply
All ideas welcomed :y
familyman
  • Sittingbourne, Kent
« Reply #243 on: 26 August 2007, 22:20:47 »
Unfortunately, the rather thing is jinxed.
Yesterday was obviously just a fluke.
If you can start the heap, it runs awful, lumpy, smokey, noisy.  No amount of pump adjustment dials it out today.
Both Omegatoy and I are entirely out of ideas now.
Time to call the local scrappy for collection methinks.
 Glad you got the old girl running, Omegatoy well on the ball. Have you tried blanking egr off or just cleaning it and check poppet valve seat. Wish i was nearer to pop round and listen and have a play :(
Are you still running 5 of 1 type of injector and then an odd 1 :-?
Actually, its currently got all the air intake off, which disconnects the egr (diesels run pretty much the same with the intake on or off, and it has to be off for adjusting the pump (and yes, same with intake on).
What is a poppet valve seat?
Still running 5 newer type injectors (1 with piezo lead), and one older type - as I was yesterday when it was working.
Yes, I wish you were nearer as well, as I simply do not know what to try now  :'(
[/quote
Sorry poppet valve is the type of valve in the egr. and the seat is the same as inlet/exh valves and these seats are prone to wearing  the same as engine valves so bad sealing to much air leaked so loss of boost pressure black smoke etc......  but as it makes no difference with it or manifold for that matter  on or off hmmmmmmmm.........  :(
What were the injector seals and if fitted the thermo seals at base of injectors like. ( theoretically crush type seals/washers and should be replaced every time but....) To much air and it will alter the crack off pressure for the injector, !st stage injection will be okay as light pressure only but 2nd stage requires higher compression pressure from cylinder, If this happens once piston has passed optimum point of injection due to air leaks poor starting and smoke etc....  I wouldn't worry about smoke visible in car headlights behind to much as it seems amplified in the headlights at night, all diesels do this to a greater or lesser degree
You came in that, your braver than i thought
« Reply #244 on: 26 August 2007, 22:25:14 »
[/quote
when we changed yesterday, a couple of the copper seals were suspect, so we put better ones from old ones on.  After pump adjustments yesterday, it was pretty good (with intake on or off), and test drive was great.
« Reply #245 on: 26 August 2007, 22:26:23 »
A gallon of 4 star & a box of Swanvestas?  ;D  ;D
There's a reasonable looking facelift (X reg?) 2.5 TD near me for £2500 (bit basic though - it has windy handle things on the back doors )  ;D  ;D
  :y   :y  :y  :y  :y
« Reply #246 on: 26 August 2007, 22:30:11 »
Oh, believe me, the thought has crossed my mind several times ;)
familyman
« Reply #247 on: 26 August 2007, 22:37:52 »
[/quote
Just an idea but it could just be that all injectors need retightening, Engine was okay when warm so seals cyl.head metals etc all expanded nicely to seal, But next day when cold a few air leaks appeared???
Also is delivery of tank to pump via filter okay. If poor delivery pump will alter timing to overcome offer biggest quantities of fuel but without the fuel there the bugger wont run no matter how much fuel it THINKS  is going through. Same as in a petrol if it wont start what do you with the throttle push it to the floor and as anybody who knows of carbs with a fuel evaporation will know it will run like a bag of well you know. ( not suggesting your's is fuel evap but poss air leak in supply system)
STMO123
« Reply #248 on: 26 August 2007, 22:39:12 »
It's just taken me fifteen minutes to read this thread from start to finish. I feel personally involved :o
I do hope it works out Jaime, it would be one of the greatest success stories to date.
« Reply #249 on: 26 August 2007, 22:39:50 »
 ;D  ;D  ;D Sorry I couldn't be more constructive!  ::)
We always seem to have a problem or two orthree or four .... with our Vauxhalls. My Astra has behaved impecably since I put it back on the road, but today for no apparent reason it has decided to show the airbag light  :( It was OK when I went into Tesco but lit when i started it on my return!  :'(
STMO123
« Reply #250 on: 26 August 2007, 22:46:45 »
You didn't put your shopping under the passenger seat? ::)
« Reply #251 on: 26 August 2007, 22:47:02 »
[/quote
Delivery pump definately working (had injection pump slightly dismantled, and when tunnie switched on ign, I got a good coating in diesel)...
« Reply #252 on: 26 August 2007, 22:48:04 »
It would be a bloody miracle ;D
Thanks for the support :y
« Reply #253 on: 26 August 2007, 22:48:46 »
You don't use the same supermarket carparks as AutoAddict do you ;D
sassanach
  • trowbridge
« Reply #254 on: 26 August 2007, 23:04:55 »
if all else fails let me know and ill bring marshmallows ;D ;D ;D ;D ;D
Pages: 1 ... 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 ... 33   Go Up
