Pages: 1 ... 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 ... 33   Go Down
Author Topic: Project Tractor engine swap  (Read 88455 times)
Re: Project Tractor engine swap
« Reply #300 on: 28 August 2007, 12:43:23 »
A jumping chain would certainly explain why it appeared to run OK and then suddenly developed issues again.
The oil in that engine looked pretty manky. Maybe the chain tensioner didn't operate correctly on initial startup, it jumped a tooth, corrected by your tweaking of the pump timing, only to jump again...
You need to have a look at that chain, methinks.
« Reply #301 on: 28 August 2007, 12:47:46 »
Both nightmare jobs. Either way, you have to take timing chain off, so my bet is scrap it and call it a day. :(
I feel that way. But I have £1500 tied up in this - more than I can justify writing off -  so need to minimise loses now, which I guess means fixing the thing.
sassanach
  • trowbridge
« Reply #302 on: 28 August 2007, 12:47:56 »
according to oracle, pump is easy to replace as pump has master spline which means it can only go in one way. pulley stays put held by special tool  which i can get.BUT my vote is remove engine swap heads and reinstall
Taxi_Driver
« Reply #303 on: 28 August 2007, 13:33:59 »
Could this be same thing?
Dunno if Disco's have the BMW lump in them  :-/
But my bro's 2.5 TD did the same as that article......it wasnt the timing chain....it waz summat to do with the pump and had a new one fitted.
« Reply #304 on: 28 August 2007, 13:41:37 »
Rangie does.
New pump? Ouch!
Taxi_Driver
« Reply #305 on: 28 August 2007, 13:47:01 »
Rangie does.
New pump? Ouch!
Well it might not have needed one  :-/ But thats what you expect when he had it recovered to a main stealer!
« Reply #306 on: 28 August 2007, 14:21:13 »
Chains/Sprockets/Guides appear to be dealer only.
Just rang the dealer....   ...assuming tensioners OK, looking around £235 + VAT....   :o
Tensioners an extra £62.50 + VAT each if they are gone.
I'm still hyperventilating.
Omegatoy
  • UK
« Reply #307 on: 28 August 2007, 14:58:28 »
;D ;D :o
is that trade price tho??? it may be cheaper if not, how much is head set??
Omegatoy
Martin_1962
« Reply #308 on: 28 August 2007, 14:59:25 »
Either 4 cyl descended from the early Diesel or the TD5
« Reply #309 on: 28 August 2007, 15:13:48 »
Eurocarparts are cheaper......
« Reply #310 on: 28 August 2007, 15:27:49 »
Going by their website, might be able to nearly save the VAT, though nothing in stock....
sassanach
  • trowbridge
« Reply #311 on: 28 August 2007, 15:35:42 »
do yourself a favour, how much is a head gasket (not set just head gasket)?
« Reply #312 on: 28 August 2007, 15:37:44 »
Won't I need the other stuff, eg rocker gasket etc etc?
sassanach
  • trowbridge
« Reply #313 on: 28 August 2007, 15:40:27 »
nope you have got all that other stuff already. you have a perfectly sweet lump sat in your garage KNOWN to work with a duff head, swap em and stop doing a balaclava :) :)
« Reply #314 on: 28 August 2007, 15:46:28 »
That must be a Wiltshire/Avon term for something, coz means nought to me, but think I can guess the meaning....
Just rang the same place I got previous HG set quotes from.  HG is around £60/£65, but need to know how many 'notches' it has, which is something to do with thickness??  They are now saying they don't list bolts, which usually mean they are not stretch bolts  :o
Pages: 1 ... 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 ... 33   Go Up
