Pages: 1 ... 22 23 24 25 26 27 28 [29] 30 31 32 33   Go Down
Author Topic: Project Tractor engine swap  (Read 88529 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Project Tractor engine swap
« Reply #420 on: 12 September 2007, 10:15:49 »
Dilute it, its best when a foam I would tip about a cup full in a bucket and fill with water and then use a broom to scrub it
« Reply #421 on: 12 September 2007, 13:37:21 »
I have the diesel tools being sent to me......when they can find them.
Much appreciated - I know how busy you've been, so didn't want to badger you about it....
« Reply #422 on: 12 September 2007, 13:38:50 »
Jubilee clips put on fuel lines, not curd the leak.  I looks like its leak from back of pump, where the 6 injection pipes are attached.  I bet I know which one is leaking - what do you reckon LFF64?
« Reply #423 on: 12 September 2007, 13:40:00 »
How much dilution - the bottle says 1:80 for general use, is that too weak/strong?  I emphasise again, its tarmac...
LFF64
  • HADDENHAM BUCKS
« Reply #424 on: 12 September 2007, 19:22:46 »
I know its very naughty but the container it is in is not the correct one I forgot to take the label off I have used it on tarmac no problems . That pipe did do up pretty tight in the end have you nipped up the injectors and the pipes to the top of them I think we said they would need to be nipped when it was back in the car. If your unsure about the cleaner I try some tesco or similar washing up liquid the cheap stuff that should be harmless to the tarmac
« Reply #425 on: 12 September 2007, 19:51:58 »
Ah, so I'll ignore the instructions then ;D
It wasn't the one we thought, it was another - still at the bloody bottom though, so had to remove 2.
So fixed the fuel leak (I think - see later), involved obviously all the intake off again (stupid bloody BMW design  >:(), topped up the autobox.  Whilst doing the autobox, I noticed (again  >:() a clear liquid dripping from the front.  Thought it was diesel, and at first thought it smelt of diesel (but may have been due to previous fuel leak).  Carried on doing the autobox, then went and checked. The liquid was hot, so presumably from the cooling system?  Engine too hot to start stripping, but top hose to block connection most likely....
LFF64
  • HADDENHAM BUCKS
« Reply #426 on: 12 September 2007, 20:25:53 »
You are right this car must be the most jinxed car in the world  ::)
LFF64
  • HADDENHAM BUCKS
« Reply #427 on: 12 September 2007, 20:27:17 »
Other than the leaks is it actually running though
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
« Reply #428 on: 12 September 2007, 20:27:39 »
If the liquid was hot and the engine was too hot to work on, then it must run and run properly. Surely that's progress?  :)
[size=24]        [/size][/b]
LFF64
  • HADDENHAM BUCKS
« Reply #429 on: 12 September 2007, 20:29:55 »
 :-[ I should have engaged brian before asking that last question sorry  :-[
« Reply #430 on: 12 September 2007, 21:13:53 »
Yup, starts on the flick of the key (well would if the battery wasn't flat due to some idiot trying to start it with the pump unplugged ::)) and idles as expected.  Haven't tried moving it yet, except up and donw the drive to clear the huge oil slick last night...
« Reply #431 on: 12 September 2007, 21:14:44 »
Oh, and to prove its jinxed, seems to have a slight ATF leak near the front, yet to pinpoint.
Golfbuddy
  • Cornwall
« Reply #432 on: 12 September 2007, 21:18:36 »
You leave Brian out of this. He's had enough trouble with Jim Davidson.  ;D ;D ;D
Taxi_Driver
« Reply #433 on: 12 September 2007, 21:23:16 »
Im suprised your driveway has melted away by now.....over 6 ltrs oil spilt on it....soaking into tarmac....has gotta make it soft  :-/  :(
« Reply #434 on: 12 September 2007, 21:34:25 »
It is getting soft, even axle stand left an impression today...
Pages: 1 ... 22 23 24 25 26 27 28 [29] 30 31 32 33   Go Up
