Author Topic: Minimum Brake Disc Depth Measurement  (Read 1486 times)
ChocolateMonster
  • Taunton, Somerset
« on: 31 October 2007, 09:56:41 »
Hi All,
Anyone know the correct minimum brake disc depth (front and rear) for a 2003 2.2 DTi Estate Omega?
Brakes seem a little spongy, but have no real way of knowing if the brake discs are below minimum depth. I have a micrometer etc, just need the minimum values....
Cheers for any help.....
« Last Edit: 31 October 2007, 09:59:46 by turner_d »
In the words of Mario Andretti, "If everything is under control, then you're not going fast enough..."
Craig_R
  • Watford
Re: Minimum Brake Disc Depth Measurement
« Reply #1 on: 31 October 2007, 10:14:29 »
check the colour of your brake fluid i am guessing that will need changing if your brakes are spongy.
You will know if your discs are knacked as there will be a massive lip on them
« Last Edit: 31 October 2007, 10:15:26 by CraigR »
Mod's
[To be Fitted]Reverse Sensors
