Author Topic: Handbrake Adjustment - 2003 Omega Estate  (Read 1582 times)
ChocolateMonster
  • Taunton, Somerset
« on: 31 October 2007, 09:59:15 »
Hi all,
Can anyone provide an idiots guide to adjusting the handbrake on a 2003 2.2DTi Omega Estate?
Mine does not really engage until the top of its travel....
Many thanks for any assistance!!
In the words of Mario Andretti, "If everything is under control, then you're not going fast enough..."
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Handbrake Adjustment - 2003 Omega Estate
« Reply #1 on: 31 October 2007, 10:07:07 »
Hi all,
Have a look at this link mate everything should be in here :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152564750
Rocketman
  • The Netherlands
« Reply #2 on: 31 October 2007, 14:02:01 »
Just like to add having done this recently, is that I found it NOT strictly necessary to remove the heat shields under the car to access the hand brake adjustment bolt. The reason being the heat shield bolts on mine, not having been touched for years, were completely rusted and sheared on attempting to undo.
I found I could get a ratchet with long entension and 13mm deep socket in from the rear and guide it by reaching in the front side. You do it more by touch than sight. There is not much room but it saves a bit of time. Also helped having access to a car lift :).
Now, how to fix those sheared bolts as my heat shield is a bit loose on one side? Drill out and re-tap? For now I can live with it.
P.S. Tried to add this to the Maintenance Guide but seems they are read-only.
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #3 on: 31 October 2007, 20:52:45 »
Send a PM to The Boy and he'll add/amend or advise :y
