Pages: [1] 2 3  All   Go Down
Author Topic: Belt change time... advice  (Read 8543 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« on: 26 October 2007, 18:19:18 »
 My local friendly mechanic's going to do my timing belt and kit. Now, I was disappointed, he didn't look even slightly nervous when I said "V6 Omega timing belt" (compared to my old boss, who had a phone enquiry for the same, screamed, said "I don't want to touch it" and hung up...).
 So, apart from the belt... what else is worth changing while he's in there - water pump, aux belt, etc...?
Re: Belt change time... advice
« Reply #1 on: 26 October 2007, 18:55:29 »
Timing belt KIT - tensioner, 2 x idlers, belt.
Water pump
Aux belt
Check the aux belt tensioner.
Make sure whoever does the work
1) uses the correct setting kit for this specific V6, and gets the timing bang on.
2) torques the pulleys up correctly, avioding premature failure.
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
« Reply #2 on: 26 October 2007, 20:26:13 »
Water pump
Aux belt
Check the aux belt tensioner. get them to regrease the ball bearings and inner race too - both sides - really easy job and saves trouble in the future :y
« Last Edit: 26 October 2007, 20:27:04 by Tafty »
« Reply #3 on: 26 October 2007, 20:39:45 »
Cambelt and cambelt tensioners need replacing together.  If the guy does not have a GM V6 cam locking/timing kit, walk away, whatever he may say.
Baz006
  • Hemsby, Great Yarmouth
« Reply #4 on: 27 October 2007, 13:09:51 »
 :-? Seriously, he may be a good mecahanic and want to help you out but if he has never done one before or doesn't have the right tools then let him down gently.... :)
« Last Edit: 27 October 2007, 13:11:12 by Baz006 »
justme
  • Shadowland
  • Testing by TB
« Reply #5 on: 27 October 2007, 21:27:44 »
Even these days there are some mechanics who do know thier stuff and never use cam locking kits, didnt someone say they used clothes pegs. Torque settings for all cars manufactured are avilable in one publication together with all other tech specs. Locking kits tend to be used by less experianced newer type mechanics (the part changers)
Test sig...
« Reply #6 on: 27 October 2007, 22:00:02 »
No disrespect intended, but that is exactly the attitude I was trying to warn about.  Some mechanics think that doing the GM V6 can be done without a locking/timing kit, same as most other engines.  It can't.  The locking/timing kit is essential.
« Reply #7 on: 28 October 2007, 01:23:49 »
I wholly agree with Jaime (yes TB, you can have that in writing ;D )
Only point to add, is that the locking kit for the V6, is also a SETTING kit, and is needed due to the nature of the micro-adjustable rollers...
You CANNOT get this right without the kit.
Richard A
  • Aldridge, West Midlands
« Reply #8 on: 28 October 2007, 13:17:04 »
Who is this idiot "Justme", please listen to the other more knowledgeable members.
I have just had the cam belt changed (including rollers, tensioner) the work was done by a Vauxhall service manager (not Vauxhall price) who used the full fitting kit, as already said it acts as a checking fixture as well.
regards
richard a
sassanach
  • trowbridge
« Reply #9 on: 28 October 2007, 13:57:17 »
well what can i say, ive never used a locking kit on a gm v6. ive always been under the impressiion that the locking kit is one of those items that make a fiddly time consuming job a doddle. what ive always done is adjust the rh bank onto its alignment marks via the rh adjustable roller with the crank on tdc,then rotate by the engine by  hand  acouple of times then bring the lh bank on line by adjusting the centre adjustable roller.  where as with a kit  you just lock the cams (on a couple of occasions ive used mole grips to do the same job ,lightly applied) and then lock the crank, change the belt and voila job done.each to there own i suppose, ive never bought the kit because i dont make a living at this, i just do it for fun.ps ive done approx 12- 15 engines like this including yesterdays 2.5 v6 WITHOUT any issues.now sits back with popcorn to await the furore and wrath of the forum
« Reply #10 on: 28 October 2007, 14:11:08 »
Sassanach - as you know, I have a huge respect for your abilities :)
Few things...
The markings on the rear cam cover plate are only a guide to initially get belt on roughly, not accurate.
Getting exact TDC without the crank lock is always going to involve guesswork.
The engine is not 'safe' at tdc, so the cam locks are easier than holding 4 cams.
Cam timing needs the timing tool, as you can't get accurate without.
Whatever you do one your own car is one thing, but if you paid someone, you would expect them to use the proper kit (seeing as its pretty impossible to get it spot on without the kit).  The number we have seen that are out shows how many are being done carelessly...
BTW - Sassanach, if ever you need the locking (and timing) kit, give me a shout...   ....it would be interesting to pop off the cover, and test with the kit to see how close you got it :y
« Reply #11 on: 28 October 2007, 14:13:02 »
...............now sits back with popcorn to await the furore and wrath of the forum
;D  ;D  ;D  ;D
« Reply #12 on: 28 October 2007, 14:13:46 »
regards
Just a member trying to help others.  I believe he is wrong in this case, but we are all entitled to our own opinions.  We all get it wrong sometimes ;)
« Reply #13 on: 28 October 2007, 16:40:17 »
 *looks at open can, and worms everywhere* :D
 Cheers guys, appreciate the advice. I'll be ringing him tomorrow, I'll ask him then. If not, it'll be either finding a decent specialist... or a VX stealer...
« Reply #14 on: 28 October 2007, 18:48:29 »
Before I become fully competent with Omegas, when I was at the "have a go, experimental" stage, I fitted a V6 cambelt kit following the Haynes manual, which said it could be done without (but would need checking afterwards).
It's only now, I know why it ran like a bag of nails!
Knowing what I know now, I would always use the correct kit.
I recon I must have done near on 30+ cambelts on the Omega for other people, and 28 of them probably weren't bang on!
Pages: [1] 2 3  All   Go Up
Page created in 0.029 seconds with 20 queries.
