Author Topic: Limb mode omega 2Ltr  (Read 1637 times)
wildwady
« on: 03 November 2007, 14:48:04 »
  Just had a head gasket change on my 2001 51 plate omega 2ltr Auto petrol LPG converted engine when picking up the car and drove off from the garage I noticed that the auto transmission light was on and while taking off it seemed to drive off very slowly gathering speed on the way.I put it on first gear and it took off normally,it seems to do it when it is on drive mode,I tried the auto transmission sport switch on the gear knob but it is not working as well. Has it got to do anything with the head gasket change ? disconnecting the battery whilst in the garage because this fault was not there before I took the car in for the head gasket replacement Any help or advise will be very gratefull
  thanks
Hi,
    thanks for the advise and this morning checked fuses and they are ok kevin advised the
electronic control maybe the garage missed a connecter or according to andy could be that the garage left the trottle position switch off right can anyone tell me were this connectors and trottle switch are please owing that the garage is closed on a weekend and cant really use the car till monday
regards
Craig_R
  • Watford
Re: Limb mode omega 2Ltr
« Reply #1 on: 03 November 2007, 16:32:51 »
If i am reading this right do you mean they never plugged the Throttle position sensor back in ?
If it is this is a black plug on the side of the throttle body looking towards the car its on the drivers side
Mod's
[To be Fitted]Reverse Sensors
Grumpy
  • Manchester
« Reply #2 on: 03 November 2007, 17:32:22 »
Wildwady, you are running 2 threads on the same defect.
I've given you the locations on your other thread.
http://www.omegaowners.com/forum/YaBB.pl?num=1194020667
