Author Topic: Towbar help requested?  (Read 6509 times)
Dazzler
  • Haverhill, Suffolk
« on: 30 October 2007, 09:06:51 »
If anyone has the above could they please look up the fitting of Vx wiring loom for a towbar,1999 mini-facelift, saloon please.
As i have a loom and apart from the main rear lights i can't see where the rest of the loom plugs into.
TIA.
« Last Edit: 30 October 2007, 09:09:17 by hotel21 »
hotel21
  • The Kingdom of Fife
Re: Anyone with TIS?
« Reply #1 on: 30 October 2007, 09:08:44 »
TIS and EPC are copywrite items available only to dealers, but will see if a friend can help us out....   ;)
Re: Towbar help requested?
« Reply #2 on: 30 October 2007, 10:42:48 »
TIA.
http://www.omegaowners.com/forum/YaBB.pl?num=1193501993
Is there any more info? :-?  Wire colour & function of both the GM wires & generic 12N wiring colours.  :-?
« Last Edit: 30 October 2007, 10:43:07 by Andy_B »
hotel21
« Reply #3 on: 30 October 2007, 10:58:50 »
Cant get help with TIS but will check my car fitting this afternoon when she gets it home from work....   ;)
« Reply #4 on: 30 October 2007, 11:52:12 »
TIA.
Can you post a picture of what you have bought? It might be possible to work it out from that.
Dazzler
« Reply #5 on: 30 October 2007, 23:10:05 »
TIA.
I will try as soon as its daylight when i am at home ::)
hotel21
« Reply #6 on: 30 October 2007, 23:11:14 »
She got home late and it was dark by then.  Hopefully will sort out a bit of wire tracing in the morning.....
Dazzler
« Reply #7 on: 30 October 2007, 23:21:57 »
Thanks Hotel21 ;)
HI2DVY
  • Deepest Darkest, Scotland
« Reply #8 on: 31 October 2007, 11:07:52 »
TIA.
Already answered this last week in your post in the electrical section...
Towbar cable colours are usually as follows...
Blue ------- Rear Fog Supply
Green ----- RH Flasher
White ------ Earth
Black ------ LH Side Lights
Yellow ----- LH Flasher
Brown ----- RH Side Lights
Red -------- Stop Lights
Purple ----- Rear Fog Lamps
Colours on vehicle harness:
Black / Blue : Fog Light
Black / White : Turn signal, Left
Red : +12v permanent
Grey / Black : Tail Lamp Left
Black / Yellow : Stop Lamp
Grey / Red : Tail Lamp Right
Black / Green : Turn signal, Right
Brown : Chassis / Negative
White / Black : Reversing Lamp
Adapter kit - Part No. 91149320 - provides connection between car loom and towbar wiring harness.
some day.....
Dazzler
« Reply #9 on: 31 October 2007, 23:41:17 »
Some pictures.
These connect to side lights and brake lights.
Side and brake other side.
Other pics conections unknown and also how the hell do you get all that loom to pass through a small hole in the bodywork??
hotel21
« Reply #10 on: 31 October 2007, 23:48:36 »
Last question first....  You disconnect wiring from trailer connection (taking note of what goes where, obviously....) then pass 9mm cable through 10mm hole, then reconnect.....
Are you simply looking for where each connector connects to the existing loom?  If so, it will be in either of the rear wheel arches.  remove the spare wheel and see whats tucked up there, towards the rear shock upper bolt??
« Reply #11 on: 31 October 2007, 23:50:16 »
Looks like those connectors are designed to loop through the connectors on the back of the light clusters. The metal tag is probably a ground connection so it needs to go under a bolt in contact with the bodywork.
I'd say the best way to feed the cable through the bodywork would be to remove the towing connector, making a note of the connections then feed the wire through and reconnect it.
Dazzler
« Reply #12 on: 01 November 2007, 00:00:48 »
The towing connecter also has a big plastic block inside ans so also is hard to strip down.
Yes, i am looking to find out where all this plugs and plays into ::)
I can only find 1 spare plug in the boot area, it is in the middle of the rear slam panel but is different to any of the plugs on the loom.
Apart from the 2 i have said which connect to the L/h and R/h rear lights i can't see where any of the others go :(
« Reply #13 on: 01 November 2007, 00:03:55 »
If this all came off an Omega I'd ask the seller how. But, this is the type of set up I got and chopped up to fit my Omega - I think mine was for a model of Astra. The plug that you have in your hand in the 6th photo should plug into a big multi relay module part number 90 513 262 (what's your German like? It also has Anhanger Modul) I baffled a few dealers with it, including the spark at dealer I got it from. There was also a buzzer that you could connect that I assume would opperate with indicators.
I gave up with it all in the end and made up a plug to fit into the square plug behind the trim using half a dozen plugs from the scrap yard.
Not much help I'm afraid.
« Reply #14 on: 01 November 2007, 00:05:57 »
That's what I did. The terminals do come out of the plug/socket, Honest!
« Last Edit: 01 November 2007, 00:06:28 by Andy_B »
