Author Topic: Fault code help need please  (Read 1634 times)
retro_al
« on: 06 November 2007, 10:29:37 »
I have done the paper clip test and it flashes 5 times then pause then 9 times,ive try to look it up but cant seem to fiqure which fault it is :'(anybody have a beter idea than me?
thanks for the help  :)
Re: Fault code help need please
« Reply #1 on: 06 November 2007, 10:33:31 »
What engine and year?
retro_al
« Reply #2 on: 06 November 2007, 10:34:23 »
is a 2.5 v6 on a n reg  :)
« Reply #3 on: 06 November 2007, 11:15:23 »
Its related to the rear multiram solenoid which is mounted on the rear of the plenum.....has the plenum been removed recently??
retro_al
« Reply #4 on: 06 November 2007, 11:17:35 »
no only thing ive done is change the plug leads and the crank sensor
« Reply #5 on: 06 November 2007, 11:23:07 »
Right
Well check the back right hand corner of teh plenum, you should see a small solenoid with a 2 pn connector and some vac hoses on it.
Make sure its plugged in and there is no damage to it.
If you look at the following picture which is a shot of the rear of the engine, you will see the item bolted to the back of the plenum...
I wonder if it was damaged/disconnected whilst the crank sensor was being changed.
retro_al
« Reply #6 on: 06 November 2007, 11:25:48 »
ok thanks for the help.i shall go have a look  :)  :y
