Author Topic: Sourcing a diff  (Read 5980 times)
Re: Sourcing a diff
« Reply #15 on: 06 November 2007, 14:26:11 »
3.0 Auto and 2.5 Auto/Manual are the same ratio, 3.0 Manual is different....
Mole
  • Midlothian, Scotland
Re: Sourcing a diff
« Reply #16 on: 06 November 2007, 14:30:08 »
I fitted an lsd to my explod mv6 and also to the 2.0 batomegabile and while they are different they will fit.
The flange at the front of the diff is bigger on the 3.0 than the 2.0 but can be swapped over.(taking care with
retightening the nut to the same position as it was taken off). Not sure about the 2.5 but the same applies.
the mounting bracket is also different but again will fit. Try to make sure you get the mount with the diff.
The drive shafts are the same fitting into the diff throughout (although different in other ways).
Hope this helps.
Brewster
  • North Lincs
Re: Sourcing a diff
« Reply #17 on: 06 November 2007, 14:53:27 »
Cheers for the help. It looks like it might be easier trying to get hold of a 3.0 manual diff as a straight swap then.
Re: Sourcing a diff
« Reply #18 on: 06 November 2007, 15:04:13 »
Its the only easy way due to the difference in ratios of the 2.5 (V6's use the same flange)
