Author Topic: Automatic transmission fault  (Read 5170 times)
Re: Automatic transmission fault
« Reply #15 on: 04 November 2007, 18:56:57 »
Hi
    was suggested to do a paperclip test and to go on faq section to see how to do it but mine is a 2001 model and on the faq at the end how to do the test it says (After 1999 the chipsets were altered so it was no longer possible to flash the codes out this way. ) is there another way ?
thanks
You can paperclip a 2.0L  :y
Its the later 2.2 you carnt  ;)
Yup, you can paperclip all 2.0/2.5/3.0 petrol Omegas :)
« Reply #16 on: 04 November 2007, 18:57:40 »
Although being a 2001, I'd be surprised if it was a 2.0l....
Taxi_Driver
« Reply #17 on: 04 November 2007, 19:50:08 »
That did cross my mind too TB......but i guess it could have been late registered  :-/
wildwady
« Reply #18 on: 06 November 2007, 18:32:30 »
Hi,
    Thanks a lot for the advise given here car went back to the garage yesterday
could find nothing wrong advised me to go to another garage and put car on computer, computer reading saying that a loose connection in the wiring somewhere ,called back garage and took it back for a double check in the end the garage jacked the car up and found one of the connectors to the gearbox was half way out of its pins back in place and lights on dash went off all back to normal now thanks again for the advise .
« Reply #19 on: 07 November 2007, 13:35:59 »
Hi,
You need to ask yourself.... why did they only spot this AFTER reading the codes...
If it was in limp mode, the first thing they should check is that everything is home !!
