Author Topic: door lock problem  (Read 1628 times)
omegarobbie
door lock problem
« on: 04 November 2007, 15:03:53 »
One of my rear doors doesn't work with the central locking. I tried a new motor but it appears there is no power going to the motor in the first place. Any ideas? where can I trace this back to?
Re: door lock problem
« Reply #1 on: 04 November 2007, 15:10:23 »
Do other electrics work on that door (eg windows)
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #2 on: 04 November 2007, 15:11:18 »
First port of call is the connector plug.
Open the door completely and you will see the rubber conduit carrying the cables from the door to the centre pillar. If you pull the rubber off as it enters the pillar you will find a connector plug just inside.
Check it is seated properly and there are no corroded or loose connections.  :y
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
omegarobbie
« Reply #3 on: 04 November 2007, 15:16:26 »
window works fine, just the lock wont pop up or down with the rest of the doors. I'll check that connector now, fingers crossed!
Kev
  • Glasgow
« Reply #4 on: 04 November 2007, 15:21:42 »
Whilst you are there, you could also check there is no broken wires etc. All that opening and shutting does tend to take it's toll.  :-/
Good luck.  ;)
« Last Edit: 04 November 2007, 15:22:00 by Kev »
omegarobbie
« Reply #5 on: 08 November 2007, 10:31:26 »
fixed!.. wire had slipped off connector. Thanks for the help
