Author Topic: slight fuel leak  (Read 1546 times)
barclay03
  • Glasgow
slight fuel leak
« on: 08 November 2007, 12:09:41 »
not sure if this is common problem or not, and as i havent had a chance to pull everything apart and check - ive got a leak behind the drivers side rear wheel, its just a drip, but it seems to be comming from a plastic 90 degree clip in the pipe... is this a common one with an easy fix or what?
Grumpy
  • Manchester
Re: slight fuel leak
« Reply #1 on: 08 November 2007, 12:25:32 »
http://www.omegaowners.com/forum/YaBB.pl?num=1186065848
Have you checked iaw the above link?
A few of us on here have found corroded pipes.
The fuel may be running down to where you are
spotting it.
barclay03
  • Glasgow
« Reply #2 on: 08 November 2007, 12:28:10 »
ah, hadn't spotted that one!  :-[ thanks, will have a check over the car an see if thats the case  :y
