Author Topic: Steering box play  (Read 1677 times)
mantahatch
Steering box play
« on: 08 November 2007, 15:15:10 »
Hi Guys
Just had my annual MOT at a Vauxhall dealer and all is well apart form 2 advisories. 1, exhaust pipe rubbers perishing, well thats no problem. And 2, slight play in the actual steering box ? Now I openly admit I no very little about steering boxes, has anyone here had a similar problem ? is it adjustable or a straight case of replacement.
Thanks in advance.
Mike
P S are the steering boxes the same for all models.
« Last Edit: 08 November 2007, 15:15:54 by mantahatch »
Re: Steering box play
« Reply #1 on: 08 November 2007, 15:20:01 »
There is an adjutment on top of the steering box, wind it clockwise half a turn (no more) and see what improvement you get
mantahatch
« Reply #2 on: 08 November 2007, 17:35:06 »
Thank you, will give it a go at the weekend.
Regards
Mike
106rallye
  • Glasgow
« Reply #3 on: 08 November 2007, 17:48:20 »
what does that do?
sideways is the way forward!
« Reply #4 on: 08 November 2007, 17:52:22 »
what does that do?
at a guess ....   adjusts the steering  ??   :)
Glenn
  • Oxfordshire
« Reply #5 on: 08 November 2007, 20:21:35 »
Slacken the lock nut and wind the screw in untill it stops, then wind the screw back slightly, no more than 1/16 of a turn, tighten locknut. You should feel the screw compressing a spring just before it goes tight, it's important to maintain pre-load on the spring without going solid.
