Author Topic: Clonking from rear  (Read 5397 times)
gofwb
  • Pudsey Leeds
Re: Clonking from rear
« Reply #15 on: 07 November 2007, 08:54:14 »
I have had this twice knocking from one side at rear when going around slow corners.
Turned out to be a broken rear spring, a section of coil can break off at the bottom, at first glance you wont notice it, but if you look closely you can tell its broken.
Kaycee
  • Doncaster
« Reply #16 on: 07 November 2007, 09:08:24 »
i had exactly same symptoms also broken spring its the tail wat goes into captive thingy hard to spot if you dont look closely
There is a tide in the affairs of man if taken at the flood will lead on to greater things
« Reply #17 on: 07 November 2007, 09:26:31 »
It is broken springs symptoms........but the user said hes checke that.
Perhaps its time for a closer check.
ians
  • Reading
« Reply #18 on: 07 November 2007, 10:51:07 »
Mark et al,
I did consider a broken spring - I know how the broken bit can lie unseen in the collar at the bottom.  I had a feel around and nothing obvious.  I'll take the wheel off at the weekend and have a closer look.
I did notice that the diff is seeping oil - I think from the prop shaft connection.   I'll top it up of course, but is there any chance this is the problem?
Cheers
Ian
« Reply #19 on: 07 November 2007, 11:02:43 »
Mark et al,
Cheers
Ian
Unlikely to be the diff pinion oil seal causing it.
What you wil find is that when you remove the level plug, oil will come out......unlikely to need topping up at all.
ians
  • Reading
« Reply #20 on: 07 November 2007, 11:07:44 »
I thought the level was supposed to be (9mm?) below the plug?
« Reply #21 on: 07 November 2007, 11:58:11 »
No, thats the manual gearbox (8mm I think), the diff oil should be level with the plug but, as the oil ages the long chain molecules get chopped up which gives an increase in volume and hence why it runs out when you check it.
ians
  • Reading
« Reply #22 on: 07 November 2007, 12:05:49 »
Ah - when I first got the car I did check the gearbox (manual) oil and it ran out when I loosened the plug - that would explain it.
Is the pinion oil seal a big job to replace?   I'm suspicious of Mr Haynes and his comments about setting up the pre setting on the pinion.
« Reply #23 on: 07 November 2007, 12:09:26 »
Its not to hard as long as you are careful, I have two to do fairly soon (including one on AA's car but, I need to get my white gloves laundered first) at which point I will add some pics to the maintenance guide (which is currently all text)
« Reply #24 on: 07 November 2007, 19:57:37 »
Vaguely remember something in TIS about a rear clonking - something to do with panelling under rear seat iirc...
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
« Reply #25 on: 07 November 2007, 20:57:38 »
I had a similar problem on mine turned out to be the rear anti-roll bar bushes worn and gone hard.
Worth a check
Glenn
  • Oxfordshire
« Reply #26 on: 08 November 2007, 20:30:20 »
Could be rear subframe bushes.........
Page created in 0.826 seconds with 20 queries.
