Author Topic: Breathers/rocker gaskets  (Read 1704 times)
« on: 09 November 2007, 14:21:18 »
Right .. I think (hope ?  :) ) I have now obtained all the required tools/cleaners/gaskets/o-rings/seals/sealant in order to replace the gaskets and clean the breathers.
I have read and re-read the "how to's" and printed out copies to take outside with me.....
I intend to strip it down, replace the gaskets, and clean the breathers as I rebuild .. does this make sense ?
Any one any other tips/tricks I need to know before wrecking doing my engine ??  :)
Finally....  having never done this .. what is a REALISTIC time scale .. I know thats a bit like "how long is a piece of string" .. but ideas would be nice BEFORE I start !!!
regards.. in trepidation ...
Entwood   :)
In nomine patris ......
Re: Breathers/rocker gaskets
« Reply #1 on: 09 November 2007, 14:24:36 »
3-4 hours for a first time.
Clean the items as you take them off and set them out ready for re-fit.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 09 November 2007, 14:25:30 »
Entwood   :)
If you are following the "How To" I should think you will be fine, just take your time don't try and rush, if it takes you all day it will be a job well done, plus saving yourself loads of money:y
ians
  • Reading
« Reply #3 on: 09 November 2007, 15:36:40 »
I would take pics and label pipes etc as you disconnect them.   In particular I found it was easy to mix up the fuel hoses with each other and the two small breather pipes.   Also there is no need to detach the throttle cable - I found that impossible - just leave it attached and clean the throttle body in situ on the car.  Also before putting the plenum back, check you haven't dislodged any HT leads off the DIS pack (I had ;)).
Worth changing your spark plugs at the same time as access is much better.
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #4 on: 09 November 2007, 21:16:05 »
Watch the Carb Cleaner too - it'll melt plastic gloves in seconds - but seems ok on skin.  Wierd but true :-/
« Reply #5 on: 09 November 2007, 22:24:49 »
You can't mix up the fuel hoses - one is 17mm, one is 19mm...
« Reply #6 on: 09 November 2007, 22:33:09 »
Thanks for all the advice .. noted and recorded .. :)
I have 3 "how to's" printed
Plenum removal
Breather cleaning
CamCover Gasket changing
Last point (at the moment) ...  would you advise scuttle removal or not ?? The how to photo's all show it still there ... but I have large hands and wonder if I'll get easier access with the scuttle off.
So if the weather is good tomorrow ........... ( wish I could actually get the car in the garage .. but that hasn't happened for 6 years !!! )
« Last Edit: 09 November 2007, 22:33:47 by entwood »
« Reply #7 on: 09 November 2007, 23:01:57 »
Plenum removal
Breather cleaning
You don't need the scuttle off for cam cover gaskets, but it won't hurt if you want to....
