Author Topic: Wiring through bulkhead  (Read 2802 times)
speakingclock
  • North Wales
« on: 11 November 2007, 00:04:00 »
Hi, Has any member found an easy route from engine bay to cabin for wiring, I have been installing LPG (Mixer System)  I have to pass abround eight sheafed wire throgh for the switch.
Many thanks in anticipation.
Tony
LPG Open Mixer System Tow Bar Mini Spots
Re: Wiring through bulkhead
« Reply #1 on: 11 November 2007, 01:22:58 »
Hi Tony,
I'll be interested in this, as I am also fitting LPG to my Omega, (SGI).
Out of interest, why are you fitting a mixer kit instead of sequential? Mixer systems do not work well with Omega.
speakingclock
  • North Wales
« Reply #2 on: 11 November 2007, 12:29:16 »
Well for ease of fitting and ease of budget I'm going with the mixer system for the time being.  The vapouriser will suit a sequential injection system at a later date. This allows me to locate a good manifold for drilling and later fit without too much disruption as the car is needed and also it's too wet and cold for the bike now.   A few points of interest, most injection modulators come equipped with standard type sprung electrical connectors.  This has necessitaded in an adaptation using two sets of 8 pin male to female connectors. On the 2.0 16 V the connectors seem to be part of the trunking for the loom. I'm sure there may be another way about, no doubt someone will let me know.  If your looking to mount the vapouriser I've mounted it under the air filter bracket  and taken the coolant pipe from the throttle body to pipe through.   The 70 Litre Stako tank fits snugly behind the rear seats fitting the frame back to front utilising the bolt holes  for the towbar with the others easily missing any obstruction through the boot floor. Had to modify an old 13mm spanner to tighten the straps though.  Have recently moved to a house without a garage so work is in slow progress.  I'll let you know any problems when all is connected.
Regards
Tony
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #3 on: 11 November 2007, 12:52:10 »
Tony
the easiest route i have found in the past has been on the passenger side, if you lift the access flap for the pollen filter you will see a couple of grommets there, that is where i have run cabling.
In order to find the entry point in the car you will have to remove the passenger side face vent, there is a how to on this i will see if i can find the link, this will give you access to the wire from the inside.
there are a few of us currently doing LPG kits, there are a few threads in general chat, would be good to have your input  :y
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #4 on: 11 November 2007, 12:55:18 »
here's the link, it is for wiring an amp but the details may help you with routing
http://www.omegaowners.com/forum/YaBB.pl?num=1155497777
speakingclock
  • North Wales
« Reply #5 on: 11 November 2007, 13:05:56 »
Thanks for that Jay, very usefull. it's p******** with rain to day so looks like a job for next week end now.
 Tony :y
« Reply #6 on: 11 November 2007, 17:15:42 »
Hi Tony,
A bit harsh methinks. Mixers should be fine, esp on 4 pots, if installed with some common sense.
speakingclock
  • North Wales
« Reply #7 on: 11 November 2007, 18:01:43 »
If it works I'll know I've got some. ;)
« Reply #8 on: 11 November 2007, 18:11:05 »
Hi Tony,
I think we might have to agree to disagree on that one - I once saw a certified mixer system on one of these backfire through the inlet, it wasn't pretty  :o
(Admittedly, driver ran the tank too low which caused this - but SGI doesn't have this effect).
I've also been talking to one of the TinleyTech guys quite a bit, who has had bad experiences with mixers on 4cyl Ecotec engines. (this was at the time I was planning to convert my 2.0)
SGI kits are clearly the way to go, and given the extremely low cost of them, I just don't think Mixers have any place on an ECU controlled engine anymore.
« Last Edit: 11 November 2007, 18:12:29 by JamesV6CDX »
« Reply #9 on: 11 November 2007, 18:11:49 »
Having said that - I do hope you see some good results with the conversion.
speakingclock
  • North Wales
« Reply #10 on: 11 November 2007, 18:41:14 »
Hi Guys, I've thought about the backfire situation and I intend to make a weighted valve to sit on the air box to prevent too much damage.
« Reply #11 on: 11 November 2007, 18:45:52 »
Just keep the tank topped up  :y  :)
magnul
  • Trondheim, Norway
« Reply #12 on: 11 November 2007, 18:53:07 »
Don't know if this is of interest, but there are some pics of the 2L connectors in this folder:
http://www.nt.ntnu.no/users/magnul/etanol/
Not LPG-conversion, but from fitting a piggy-back system for ethanol conversion.
speakingclock
  • North Wales
« Reply #13 on: 11 November 2007, 22:44:51 »
Hi That could be worth a re-think.  Thanks
Tony
