Author Topic: 2.5v6 conversion into 3.2v6....  (Read 5830 times)
Arebee
  • Wickwar
« on: 09 November 2007, 17:57:29 »
Does anybody know if a 3.2v6 auto 52 plater engine will go straight into my 2.5v6 manual 1998 hole ??  or does this need some adaption ??  all the help would be appreciated as i have the 3.2 engine but nobody seems to know if it will go straight onto my manual gearbox and i dont fancy pulling it all out to have to put the 2.5v6 back in !!
Cheers guys
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: 2.5v6 conversion into 3.2v6....
« Reply #1 on: 09 November 2007, 18:01:48 »
 I'm thinking you'd need a manual flywheel, don't know if the 2.5 one would fit. Electronics would need some work, with the 2.5 having cable, 3.2 being fly-by-wire. But I'm in no way an expert, I've only enough knowledge to be mildly hazardous when unsupervised.
Arebee
  • Wickwar
« Reply #2 on: 09 November 2007, 18:08:55 »
What do you mean by fly-by-wire ???
ghondie
  • sheerness,kent,uk
  • Looking for work, any offers?
« Reply #3 on: 09 November 2007, 18:10:43 »
i think he means that things like throttle control are done by electronics and not by a physical cable running from pedal to intake,
could be wrong tho
cheers
nathan
Man with a mission. not sure what it is but i've got one
Sheerness Lifeboat Crew and ILB Mechanic
Arebee
  • Wickwar
« Reply #4 on: 09 November 2007, 18:21:05 »
so how difficult would it be to add these 'fly-by-wire' 'electronics' into my car ???  i do have the whole 52 plater 3.2 car so i have access to all the parts ??  somebody must have done this already i can't be the only one dreaming of this ! am i ???? :o
« Reply #5 on: 09 November 2007, 18:36:47 »
 In that case, you'd have to see how much of it you can swap - I'd imagine you'd need the ECU and loom, but then you'd have to use one of our friendly Tech2 operators to get it all working with the various systems.
 To be honest, the 3.2 only has en extra 10bhp over a 3.0, you'd probably have less hassle putting in a 3.0 engine.
HTH :y
« Reply #6 on: 09 November 2007, 19:01:40 »
To do it you need to swap the engine management from your 2.5 to the 3.2 bare block and loose the coil per plug setup.....do this and its feasable.
Arebee
  • Wickwar
« Reply #7 on: 12 November 2007, 15:39:58 »
so is this going to be so much easier just to use a 3.0 lump then ??  whats the power difference between the 2.5 and 3.0 anybody know ??
And does anybody know about say supercharger either the 2.5 or 3.0 engines ??  do the engines themselves need alot of work to be able to handle the extra power or do they survive ????
« Reply #8 on: 12 November 2007, 18:24:40 »
I personally would just put some 3.0 cams in the 2.5....
Arebee
  • Wickwar
« Reply #9 on: 12 November 2007, 19:03:35 »
how much extra would this give me ?? and is it an easy job to do ??
    • 530D M Sport, 330i Coupe
« Reply #10 on: 12 November 2007, 19:23:55 »
I think it's + 20BHP but somebody would need to confirm, it's the same mod as Vauxhall (Well MSD) did with the Vectra 2.5 GSi
« Reply #11 on: 12 November 2007, 19:41:11 »
An easy 20bhp, pushing it very close to a 3.0. Add a MTEK chip, and it will be great, V close to 3.0 power, with no need for all the heavy mechanical work!
Cams are easy enough, just like doing a cambelt and cam cover gasket change, with a few more bolts ;)
vvm
  • bisley surrey
« Reply #12 on: 13 November 2007, 10:14:46 »
the 3.2 engine will fit straight onto your gearbox, the mounts etc are all the same but you would need to swap both inlet and exhaust manifolds and engine loom from your original engine when the engine is out, which is very straightforward with the engine out.
has anyone ever put a car on a dyno before and after 3.0litre cams been fitted? i`ve always been dubious about the power gains from just fitting cams, cant see how they can bring the power up so close to the 3.0litre engine which already has those cams fitted!
106rallye
  • Glasgow
« Reply #13 on: 13 November 2007, 12:51:06 »
id be interested on that as well. i dont understand how putting 3.0 cams in the 2.5 will give good gains. the 3.0 will always have more torque and bhp is rpm x torque so how can the 2.5 get to similar power to the 3.0  :-?
sideways is the way forward!
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #14 on: 13 November 2007, 14:34:20 »
complete agreement - gains outwith this are marginal. Gains of 3.2 over a 3.0 are also marginal.
