Author Topic: heater matrix  (Read 1973 times)
salvo3.0
  • wiltshire,swindon
heater matrix
« on: 13 November 2007, 19:38:59 »
as every one is complaining about there heaters,
can some one tell me how to flush the heater matrix.
it's always mentioned but knowbody says how to do it .
Dazzler
  • Haverhill, Suffolk
Re: heater matrix
« Reply #1 on: 13 November 2007, 20:12:08 »
You need to remove both hoses to the matrix and apply a hose pipe to one of the holes left and flush then go in the other hole and back flush.
salvo3.0
  • wiltshire,swindon
Re: heater matrix
« Reply #2 on: 13 November 2007, 20:53:07 »
is there a way of doing it with out striping the dash to acess the matrix,
can i get at the pipes in the engine bay somewhere.
Re: heater matrix
« Reply #3 on: 13 November 2007, 20:57:41 »
I dont think so,
if you dont remove the dash completely and try to play with matrix you will break some plastic parts holding the screws on the dash (one is just behind the big plastic pipe behind the steering wheel be careful)
markey mark
  • SLady bitshorpe north lincs
Re: heater matrix
« Reply #4 on: 13 November 2007, 20:58:22 »
yes mate under bonnet down drivers side of engine you will see pipes coming out of bulkhead  :y
salvo3.0
  • wiltshire,swindon
Re: heater matrix
« Reply #5 on: 13 November 2007, 22:36:38 »
i don't surpose any body has any pics of these pipes.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: heater matrix
« Reply #6 on: 13 November 2007, 22:42:58 »
Just look down between the brake servo and engine at the bulk head, you will see 2 pipes comeing through. remove the clips and attatch a hose to one and flush the matrix untill clear water comes out . Reconnect the hoses and refill with coolant.
Jaguar XJ6
salvo3.0
  • wiltshire,swindon
Re: heater matrix
« Reply #7 on: 13 November 2007, 23:00:36 »
thanks i'll give it a go
