Author Topic: heater, climate control  (Read 1673 times)
big_lebowski
« on: 15 November 2007, 22:13:54 »
having a problem with the c/c, the fans in side the omega would not work at all the other day but came to live later that day but when I turned the engine off the fans inside continue to run even when the key is removed from the ignition.
They ran the battery flat, I have charged the battery so that is now fine and the car runs fine but I have had to remove the fuse for the fans to stop them running.
The drivers side of the omega runs cold constantly and the passenger side hot air constantly. why?
what could be the problem?
Re: heater, climate control
« Reply #1 on: 15 November 2007, 22:25:37 »
Is your scuttle drain blocked?
big_lebowski
« Reply #2 on: 15 November 2007, 22:31:10 »
where is the scuttle drain? how easy is it to clear if it is?
« Reply #3 on: 16 November 2007, 09:49:30 »
Rear right of the negine bay is a plastic cover through which teh wipers poke....on the right there is a flap that can be lifted up once the rubber seal along the font edge has been lifted.
In here is the scuttle (and the pollen filter), the drain is at the bottom....there should be no water in it and any water that gets in there should drain away.
Page created in 0.049 seconds with 20 queries.
