Author Topic: Odd heater problems with v6 2.5  (Read 1711 times)
sbennetts
« on: 16 November 2007, 15:33:28 »
Hi,
I've got a 2000 W plate Omega 2.5 V6 CDX which has climate and air con. My problem is that when the heater is on, the only vents that blow out hot air are the rear ones!! That obviously shows the heater matrix is working and that the car is arriving at the correct running temperature at some point.
If using the demister or opening the front vents or actually the heater anywhere in the front, I turn into an ice cube very quickly!
Any thoughts?
Thanks
Simon
PS. Before I bought it recently, it had a problem with the oil cooler which was replaced and all flushed out.
sophos9
  • Norfolk
Re: Odd heater problems with v6 2.5
« Reply #1 on: 16 November 2007, 15:34:48 »
Have you reset the climate control? Do this by holding down AUTO and OFF...
« Last Edit: 16 November 2007, 15:37:07 by sophos9 »
« Reply #2 on: 16 November 2007, 15:41:10 »
Sounds like classic vac feed fault....my money is that when the oil cooler was done soemthing at the back of the engine was disturbed and not put back properly.
sbennetts
« Reply #3 on: 16 November 2007, 15:43:13 »
I haven't, I'll give that a go.  What does that achieve?
Is that likely to give the affect of heat for the rear passengers and Siberia in the front?
Thanks
Simon
sbennetts
« Reply #4 on: 16 November 2007, 15:45:12 »
Hi Mark, thanks
Where do I find that bad boy?  Is it just a standard vacumn pipe?  If the car is running will I be able to hear a whole lot of sucking going on in the engine bay somewhere?
« Reply #5 on: 16 November 2007, 15:53:09 »
If you look in the maintenance guide section you will find info on where the vac pipes in the engien bay run
The ones to check is the one that goes from the rear left of the engine bay where it attaches to the brake servo vac feed and passes across the rear of the engine to the pollen filter/scuttle area.
A second pipe then travels back across the rear of the engine to the rear left of the bulk head and connects to the point where the heater matrix pipes pass through to the cabin.
A further shorter pipe then comes from the point where the heater matrix pipes pass to the top of the heater bypass valve.
Also check that the brake servo pipe is securly connected to the plenum (right side) and that the pipe is not damaged at all.
« Last Edit: 16 November 2007, 15:53:57 by Mark »
sbennetts
« Reply #6 on: 16 November 2007, 15:58:18 »
Thanks both for the quick response, I'll take a look in the morning and see where we stand.
Simon
