Pages: 1 ... 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 ... 22   Go Down
Author Topic: Oh Bugger - The END?  (Read 87406 times)
Allenm
  • Milton Keynes
Re: Oh Bugger - The END?
« Reply #135 on: 04 August 2006, 12:06:10 »
Doing a cambelt change tomorrow so will photo it and post the results as a guide.
That will be a great help!  If you have a camcorder and could vidoe the procedure, I would happily pay for a copy of the tape.
Could you post a picture of the contents of the cambelt kit?
Thanks
Merv
« Reply #136 on: 04 August 2006, 13:23:16 »
The cambelt kit contains (from memory) the belt, the tensioner (which is the tensioner below left hand cams (your failed one) and between the cams), and a roller (halfway down on right).
« Reply #137 on: 04 August 2006, 14:43:30 »
Cam belt kit contains:
Cambelt
Tensioner and upper idle roller on new cast backplate
Lower Idle roller
New lower idle roller spacer
New bolts
Allenm
  • Milton Keynes
« Reply #138 on: 04 August 2006, 14:46:45 »
Thanks for that! I will hang on until I see the results of your change tomorrow (or whenever you post),  If there is a chance of a video production (ala Robin Hood),  let me know and I will PM you an address for the disc, and paypal you some readies for it and the t-piece.
Cheers
Merv
PS.  Anyone able to help with a Trade card?
« Reply #139 on: 04 August 2006, 16:31:00 »
I cannot help with TC at moment - sorry.
Robin Hood
  • Nottingham
« Reply #140 on: 05 August 2006, 13:53:18 »
Allenm pm me your address and I will get a copy of the video(DVD) to you Monday.  I think it stands at about an hour and a half at present so will need some serious editing before general release.   ;D
Allenm
  • Milton Keynes
« Reply #141 on: 05 August 2006, 16:24:12 »
PM sent  :)
Thanks to all for arranging this!! Especially to Mark for becoming a luvvie for the day!!  ;D
Cheers
Merv
nixoro
  • Hitchin, Herts
« Reply #142 on: 07 August 2006, 07:27:56 »
Having read a few post back I maybe able to help with the tool side of it as I have collected quite a few.
Torque wrenches included.
Should save on puchase costs
PM me as I am not that far away.
I maybe able to help.
HTH
johnny.dee
  • essex
« Reply #143 on: 14 August 2006, 12:08:47 »
Whats the continueing saga, nothing posted since the 7th August. I am about to tackle my cambelt?
« Last Edit: 14 August 2006, 12:09:27 by johnny.dee »
Allenm
  • Milton Keynes
« Reply #144 on: 14 August 2006, 13:24:28 »
The current status of this sorry saga is..
having stripped down to the check the state of the belt (Thanks to Theboy), it has slipped a couple of teeth.  Mark DTM has suggested re-allignment of the cams, new belt and hope like hell.
So the next step is to get the cambelt kit, water pump etc and do the following. Roate the crank to 60 degrees before TDC, Which I am hoping the steps below are correct (Confirmation?).
1. remove the locking tools
2. Turn the crank (clockwise) until the notch mark labelled 1 on the first cam from the left is at approx 8 o'clock.
3. remove the belt
4. turn (by hand?) all the cams until their marks correspond to the notches on the backplate then fit the red and green locks.
5. turn the crack until its TDC point (without a belt on) and fit the locking thing onto the water pump.
6. Change the belt.
7  Put it all back together  :-/
8. Turn it over and drive off into the sunset ;D - or not  :'(
I will post the results when I have a go, probably this weekend,  well lets be honest, I will post loads of really noddy pictures asking where bits go ;D
« Reply #145 on: 16 August 2006, 09:28:18 »
Step 2 is wrong, you need to turn the crank until its 60 deg before TDC, the cams would only be 30 deg before the timing mark ...
You will probably need a torx bit to rotate the cams or grip the pulleys using the old belt.
Allenm
  • Milton Keynes
« Reply #146 on: 16 August 2006, 10:29:21 »
Cheers Mark!  I suspected that I might have got that bit wrong :(
I now have the parts, so will start this afternoon,  60 deg before TDC I am going to do this.. is this right?
with the locking kit in place (which I assume makes in certain to be at TDC) make a mark on the crank sprocket at 12 o'clock, turn it (through 300 deg) until the mark is at 10 o'clock.
Are there any markings on the crank that I can use to double-check?
« Last Edit: 16 August 2006, 10:33:08 by Allenm »
« Reply #147 on: 16 August 2006, 10:47:08 »
There are markings on the crank and pulley but, they are not easy to spot, with the locking kit fitted its at TDC.
Better to make a mark.
johnny.dee
  • essex
« Reply #148 on: 16 August 2006, 10:52:17 »
confidence is the key to success, before I tackled the oil cooler problem I had never worked on an engine containing a multitude of parts and electronic gizmos. Now that is finished and feeling very confident, I intend to do the timing belt and accessory belt next before I end up with your problem.
Go for it Al.
Allenm
  • Milton Keynes
« Reply #149 on: 16 August 2006, 15:05:20 »
OK - First update of many
* removed the old belt and re-aligned the cams as per the following pictures.
Cam 1
Cam 2
Cam 3
Cam 4
Does this look right?  I have put the locking bits in, and am about the re-turn the crank to TDC, before chaning the pump etc..
Pages: 1 ... 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 ... 22   Go Up
Page created in 0.032 seconds with 20 queries.
