Pages: 1 ... 13 14 15 16 17 18 19 [20] 21 22   Go Down
Author Topic: Oh Bugger - The END?  (Read 87254 times)
Re: Oh Bugger - The END?
« Reply #285 on: 07 October 2006, 11:47:59 »
UncleF, a member here has produced a cambelt change DVD, not sure on postage to Cyprus, but its worth its weight in gold.
Don't attempt without locking/timing kit.
Martin_1962
« Reply #286 on: 07 October 2006, 20:23:57 »
In the region of £1.50 - I've been selling DVDs to Greece
Allenm
  • Milton Keynes
« Reply #287 on: 10 October 2006, 20:26:50 »
Planning to strip the car down tomorrow so that it is all ready for Saturday assuming all is still go.
Mark, can you let me know what bits you have got and are bringing and PM me a cost for it all so I can get the cash ready.
Now just need to know who is coming along so I can sort out getting the refreshments,  was thinking Bacon butties first thing, then a big pan of Chilli, chicken drumsticks etc for lunch and as much tea/coffee as can be drunk,  let me know if that don't appeal (no problem changing the menu ;) ).
Oh yeah, is carb cleaner called that? or does it have a trade name,  can't seem to find it on any websites, I guess Motorserv will have it, just need to know what it is called  :-[
« Last Edit: 10 October 2006, 20:27:29 by Allenm »
« Reply #288 on: 10 October 2006, 20:41:40 »
Motorserv will sell - should be around £2 - £2.50 for large aerosol. Beware, Halfruads want an Ayrton a pop  >:(
Get 2 or 3 cans.
I'll certainly be there, may have to leave before all done, as gotta tow caravan to Santa Pod  >:(
Anything you need me to bring?
MartinP
  • Dudley
    • BMW 320D
« Reply #289 on: 10 October 2006, 22:35:25 »
Will be there (if you pm your address  ;))
What time is the kick off?
Will be bringing most of my tools, (and a big hammer), just in case the professionals forget a screwdriver of something  :)
« Reply #290 on: 11 October 2006, 08:34:17 »
We have got
  • Two re-furbished heads with exhaust manifolds flattened and fitted along with new studs, Vx gaskets, new stem seals, cleaned and re-ground valves plus cleaned lifters.
  • Headgasket kit including head bolts and cam cover seals.
  • 4 off coolant bridge seals
  • 4 off oil cooler banjo seals
  • 1 off coolant pipe to block O ring
  • 2 coolant pipe to stat housing O rings
  • Grey Selaent (oil cooler plate)
  • Black sealent (cam covers)
  • Green sealent (front cam bearings)
  • Grease
  • Copper grease
  • Oil can
  • WD40
  • Rust flash
  • Solvent cleaner
  • Kitchen paper
  • Gloves
  • Spares (bolts etc)
  • Tywraps
  • Spare vac pipes
  • Cam lock kit
  • Torque wrench settings
  • 5 litres of Oil (semi synth)
  • 5 litres of antifreeze
  • Oil filter and sump plug seal (paper element)
  • 6 spark plugs
Matchless has the bill(s)
Allenm
  • Milton Keynes
« Reply #291 on: 11 October 2006, 09:28:17 »
We have got
  • Grease
  • Copper grease
  • Oil can
  • WD40
  • Rust flash
  • Solvent cleaner
  • Kitchen paper
  • Gloves
  • Tywraps
  • Spare vac pipes
  • Cam lock kit
  • 6 spark plugs
Blimey!   :o  Glad you guys know what you are doing,  the list of bits has lost me  :-[
What time are you planning to start,  I'll make sure the gazebo etc, is ready beforehand, and get the kettle on!  :)
« Reply #292 on: 11 October 2006, 09:39:00 »
Planning to leave Nottingham about 8.00am....so shoudl eb there shortly after nine Oclock.
Can you PM me your address and phone number.
Matchless
  • Nottingham
    • A white van
« Reply #293 on: 11 October 2006, 10:33:51 »
Will PM the bill tonight.
Rock
  • Windsor, Berkshire
  • Right turn Clyde...
« Reply #294 on: 11 October 2006, 16:39:54 »
I'm sure you guys don't need luck, but I just wanted to wish you all the best for the weekend.
Wish i could be there to see it happen, if only for the bacon butties.....
Cambelt changed 03/12/06.
Allenm
  • Milton Keynes
« Reply #295 on: 12 October 2006, 11:56:29 »
I Started stripping down the cambelt yesterday in between the downpours!
When I did the blow/suck test of the metal air pipe, I received a lungfull of sooty air  :(
I guess this means that the non return valve is gone.
Is this repairable or do I need to be getting a replacement?
« Reply #296 on: 12 October 2006, 12:09:39 »
Got a spare, I was going to bring it with me anyway.
Heres a pic of the two assembled heads:
Allenm
  • Milton Keynes
« Reply #297 on: 12 October 2006, 12:22:02 »
Great, Thanks Mark!
The heads look great!  I better get out and start polishing the car ready for them  ;D
Starting to feel like a kid at christmas at the thought of getting the meega back ! ;D
MartinP
  • Dudley
    • BMW 320D
« Reply #298 on: 12 October 2006, 21:03:13 »
Hmm! they didn't look like that last time I saw them  ::)
Matchless
  • Nottingham
    • A white van
« Reply #299 on: 12 October 2006, 23:34:45 »
Ive still got all the muck and gunge if you want it back. ;D
Pages: 1 ... 13 14 15 16 17 18 19 [20] 21 22   Go Up
