Author Topic: 2.5Td diesel injector pump  (Read 2055 times)
busastars
  • Gwent
« on: 15 November 2007, 16:38:05 »
Just wondering if all the 2.5Td injector pumps are all the same. Also are they all the same on the 2.5 BMW. If not are they interchangable?
Also where is the best place to get one second hand?
« Last Edit: 15 November 2007, 16:40:18 by busastars »
Re: 2.5Td diesel injector pump
« Reply #1 on: 15 November 2007, 16:42:28 »
They are the same....speak to The Boy, he has a known good one he might be willing to part with.
Omegatoy
  • UK
« Reply #2 on: 15 November 2007, 20:23:05 »
as i understood it pumps are all the same but the sensors are management specific? i.e an later pump wont run an earlier engine due to differnces in the pump signals?
« Reply #3 on: 15 November 2007, 20:42:16 »
In BMW documentation there is a note that a newer pump can't be used on an older ECU (think that is the right way round).
Omegatoy
  • UK
« Reply #4 on: 15 November 2007, 21:23:31 »
thats what i was on about but couldnt remember the exact words!!! :-[
« Reply #5 on: 15 November 2007, 22:22:23 »
Must be your age  :P
Omegatoy
  • UK
« Reply #6 on: 16 November 2007, 21:06:22 »
Must be your age  :P
:o :o >:( ;D
busastars
  • Gwent
« Reply #7 on: 18 November 2007, 18:49:33 »
So the older pump & potentiometer can be used on a later version? Is that right? I have been trying to get a spair one from loads of places and know one has one, just would like to try changing to see if this cures my problem, may also change number 3 or 4 injector, the one with the sencer on, to try and eliminate things.
« Reply #8 on: 18 November 2007, 19:04:26 »
I believe so.  My BMW info is not currently installed.
The injector with needle sensor is No 4, and the electrical connector does vary with age.
