Author Topic: Squeeling on startup  (Read 2330 times)
RichB
  • Loughborough
« on: 19 November 2007, 20:56:32 »
My car has recently started sqeeling on startup, this lasts varying amounts of time.  Originally I thought it was auxilliary belt but it doesnt sound like any other car i've had when its had a slipping aux belt.  Could it be anything else making a squeeling sound?  And why would it go away / get quieter over time?  How do you check / adjust the tension of the aux belt?  It should be ok as it was changed when I had the cambelt done.
Cheers,
Richard
Re: Squeeling on startup
« Reply #1 on: 19 November 2007, 20:59:02 »
If its a bearing on its way out it could stop the noise as it warms up ....:(
I would suggest removing the aux belt completly, then run the engine for a few minutes when cold ... if the noise has gone it is one of the items on the auxbelt....  if it is still there at least you now know what it isn't !!!
« Reply #2 on: 19 November 2007, 21:09:00 »
Err, the water pump wont be running then!!!!!
« Reply #3 on: 19 November 2007, 21:10:25 »
Cheers,
Richard
Is the noise coming from just in front of the passenger wheel, and lasts for about 30 - 45s?
arthill
  • Greenock
  • HI all pleased to join Forum
« Reply #4 on: 19 November 2007, 21:16:39 »
If not belt possibly water pump, some Omegas water pump driven by timing belt.
  John
John
RichB
  • Loughborough
« Reply #5 on: 19 November 2007, 21:17:07 »
No it does sound like its coming from the front of the engine in the middle.  It changes with engine revs also.  What bearings could be going?  Are they easy to change?
« Reply #6 on: 19 November 2007, 21:19:46 »
Check the cambelt and pulleys are OK. One slipped cambelt is even for this week!
« Reply #7 on: 19 November 2007, 21:21:03 »
2 minutes with no water pump won't do any harm ..... and would aid diagnosis ?
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #8 on: 19 November 2007, 22:23:19 »
I have a simular squeak when my car is cold, sounds like its coming from the front of the Plenum :-? as soon as its warmed up though its gone weird.
I have Cambelt, Tensioners and water pump done about 7,000 miles ago......
JasonH
« Reply #9 on: 19 November 2007, 22:43:43 »
Hang on....it sounds like the secondary air injection pump to me.
Noise lasts for up to 2 mins depending on how cold the engine is. Screeching sound. Very common. A quick and perfectly satisfactory fix is to unplug the pump, or remove the fuse.
JasonH
« Reply #10 on: 19 November 2007, 22:44:41 »
Oh and it changes sound with the revs because the battery voltage goes up and down a little.
Varche
  • Online Online
  • middle of Andalucia
    • Golf Estate
« Reply #11 on: 19 November 2007, 22:47:33 »
Hi
I had this on my Omega recently. It too was hard to pinpoint where the noise was coming from. Long story short it was the aux belt, fairly easy to change but make a note of where the belt runs before you take it off.
You can't adjust them as it is done automatically by a spring loaded pulley. If you do replace it I would recomend using the genuine VX part.
I think they stop squealing with increased revs or when the engine is warm because there is less load on the belt.
You could try the following. As soon as it stops put the air con on and your headlights, heated rear screen and see if it comes back. Both the alternator and air con are driven by the belt.
varche
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #12 on: 19 November 2007, 22:54:59 »
To be honest I thought it was coming from the Water Pump orginally, so I put some WD 40 over it and when that didn't cure it over the other pulleys too. I did think it was the Cams as it is that area, not getting enough oil up when cold but its not a fast squeaking noise if that makes any sense, more like a pulley or even the air con but it is definately up near the Cam Covers, Water Pump, Plenum area :-?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #13 on: 19 November 2007, 22:56:59 »
Hi
varche
I changed my Aux belt and the Tensioner but still have the noise :-?
