Author Topic: Oil cooler or head gaskets?  (Read 2022 times)
spudmariner
  • Portsmouth, Hampshire
« on: 19 November 2007, 01:17:06 »
I bought an S reg 2.5 CD a few weeks ago and was told the gaskets had been recently done. There was no sign of pressure in the expansion tank but a little bit of 'mayo' in both the expansion tank and oil filler which I assumed were left over from when the gaskets went. The car drove perfectly for a couple of weeks and then the oil level dropped drastically, ending up in the water cooling system so that it looked like neat oil was cooling the system. The car still drove fine and no untoward exhaust fumes. The bottom hose burst in traffic and was recovered home but still starts fine and pulls on all 6 cylinders. Before I put it in the hands of a garage could anyone give me any pointers please. Thanks
IrmscherKris
  • Manchester
  • banned due to bad trader references
Re: Oil cooler or head gaskets?
« Reply #1 on: 19 November 2007, 01:32:02 »
Oil cooler  :y
« Reply #2 on: 19 November 2007, 08:30:34 »
Its a no brainer....oil cooler.
Consider this (and then you will be able to question any garage who says other wise)
On a head gasket there are
1) Lots of pressurised coolant ways
2) Lots of oil return ways, these are LESS than atmospheric pressure due to the engine breather system.
3) One small high pressure oil feed which is quite some distance from any of the other bits.
Then consider how a headgasket fails....its often due to the composite material failing (due to in-correct anti freeze mix generaly) which results in the main fire rings losing support and being pushed outwards, around the fire rings are water passages and the result is a pressurised coolant system and water in the cylidners.
Its pretty much impossible for the high pressure oil feed to fail into a water way....and if the gasket failed between the coolant and the oil return ways then you would get water in the coolant... (remember that the coolant pressure is much higher than the crank case).
The symptoms you have do NOT fit the above.
In the case of an oil cooler failure you need to remember the following:
The oil is high pressure in the cooler as it is after teh oil pump and filter. It sits in a bath of coolan which is also pressurised under normal conditions. The oil pressure is higher than the coolant pressure so with the engine running you get oil mixing with the water, this get stirred up and creates a mayonnaise...
So, how do you get SOME water in the oil.....elementary.....after turning the engine off, the oil pressure drops but, the coolant remains pressurised so some coolant now gets into the oil....not much mind but some.
Hope that helps...
As a guide, oil cooler is about 80-90 quid plus about 40 ish of extras (oil, filter, antifreeze, seals) and takes about 3 hours plus a coolant system flush.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 19 November 2007, 09:54:40 »
Mark is the man on these cars mate, what he doesn't know about cars isn't worth knowing everyone on here will say the same. So you can safely say what he has said is right :y
« Reply #4 on: 19 November 2007, 18:39:28 »
What MDTM says above.
If I may add, don't drive it with an oil cooler failure, it tends to damage other parts (all rubber hoses go soft, rad blocks, waterpump fails etc etc)
spudmariner
« Reply #5 on: 19 November 2007, 22:55:22 »
Thanks for all your help and now I can move on and get it sorted. Hoping to move up to an MV6 next year so I'm looking forward to reading more info on this site. Thanks again.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #6 on: 19 November 2007, 23:59:00 »
and again as MDTM said...
Mark - that was a darn good read  :y
