Author Topic: Exhaust emission light  (Read 2201 times)
ronmk
  • Milton Keynes
« on: 29 October 2007, 09:46:53 »
Just had a new exhaust fitted,after 140 miles the emissin light has come on.
Should i worry about this
ronmk
  • Milton Keynes
Re: Exhaust emission light
« Reply #1 on: 29 October 2007, 13:04:53 »
Any ideas please??
ronmk
  • Milton Keynes
« Reply #2 on: 29 October 2007, 13:06:08 »
Should have mentioned its an 02 Omega 2.2 litre
Thanks
The Cambelt Kid
  • Derby
« Reply #3 on: 29 October 2007, 15:10:52 »
Did you get the whole system inc cats replaced and was the kit genuine?
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
ronmk
  • Milton Keynes
« Reply #4 on: 29 October 2007, 16:12:43 »
whole system replaced,dont think its a GM one
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #5 on: 29 October 2007, 18:15:21 »
You need to get the codes read with a TechII, where abouts are you?
It would help if you updated your profile with car details/location etc.
I like red cars
« Reply #6 on: 29 October 2007, 21:50:21 »
on a 2.2, you will need to get the codes read so we can see what the ECU thinks is wrong.
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #7 on: 29 October 2007, 22:00:29 »
It could be that one of the oxygen/lambda sensors has been damaged as that would pick up a fault code, or it could be an air leak unconnected to the exhaust or just the ECU getting used to the new flow and it may sort itsself out.
In order to remove the guesswork and prevent any damage to your car as suggested the best thing is to get the codes read by a Tech2.  Vauxhall will charge £50+ for this so best to find an independant garage with the technology.
Post the codes back here ie PO100 etc and TB will tell you what it means and how to fix it.
It's ok for now, but may use more fuel than normal, but if it flashes you should get it to a garage asap.
Good luck.
« Last Edit: 29 October 2007, 22:19:09 by Chopsdad »
« Reply #8 on: 29 October 2007, 22:04:40 »
And if you are need Brackley or Nottingham, see http://theboy.omegaowners.com
DaveG
  • Bracknell, Berkshire
« Reply #9 on: 21 November 2007, 21:43:11 »
Hi, I'm experiencing exactly the same issue with light coming on between 140 - 250 miles. The fault code is P0420 - Catalytic Converter below threshold (Bank 1). Both O2 sensors replaced and wiring OK. In my case it looks like I need to speak with Eurocat (EEC) in Portsmouth who supplied the replacement cat.
How are you getting with yours?
DaveG
ronmk
  • Milton Keynes
« Reply #10 on: 21 November 2007, 22:08:27 »
Had the exhaust changed yesterday,light still on,waiting for it to go out now.
Or do i have to have it reset.
Ron
« Reply #11 on: 21 November 2007, 22:10:33 »
Ron
Might be as well to reset it...
