Author Topic: engine starts runs  then idles rough and dies  (Read 1716 times)
buggkilla
« on: 22 November 2007, 05:44:59 »
2000 cadilac catera engine will start every time idles up to 2000 then falls to below 500 and dies need posible causes
Re: engine starts runs  then idles rough and dies
« Reply #1 on: 22 November 2007, 07:36:48 »
The first thing to do is read your fault codes.
ians
  • Reading
« Reply #2 on: 22 November 2007, 11:04:34 »
The 2.0 breather/throttle body/ICV clean up would be my first port of call.
« Reply #3 on: 22 November 2007, 11:14:06 »
3.0V6 engine only in the caterra...
I would give the idle valve a dam good clean out as a starter for ten.
Does it run ok with a little light throttle?
Other possibles are an air leak.
ians
  • Reading
« Reply #4 on: 22 November 2007, 11:17:25 »
b@llocks - I misunderstood the 2000  :-[
Martin_1962
« Reply #5 on: 22 November 2007, 13:19:59 »
It's a DBW Mark
« Reply #6 on: 22 November 2007, 13:27:33 »
The little throttle trick still works on DBW units.....
lawbet7eb
« Reply #7 on: 22 November 2007, 17:25:58 »
disconnect air flow meter then try to start it,,,
buggkilla
« Reply #8 on: 22 November 2007, 23:13:24 »
you R my hero, lawbet - mass air flow was the problem!! thanks SOOOO MUCH
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #9 on: 22 November 2007, 23:19:50 »
Thats rare for a MAF to fail. :o
Jaguar XJ6
« Reply #10 on: 23 November 2007, 08:37:29 »
VERY rare....not running an oiled cone filter by any chance?
Page created in 0.023 seconds with 20 queries.
