Author Topic: Correct type of anti-freeze to use  (Read 1747 times)
wayneywoo
  • Hemel Hempstead
« on: 22 November 2007, 14:06:17 »
Hello all,
Just looking through the TIS and wondered what people's opinions are regarding the particular type of anti-freeze to use.  Mine's a 2.0ltr '99 and the TIS says up to MY 2001 (What's MY 2001?) to use Blue and after that Red.
I've bought the red long life anti-freeze from Halfrauds and am now wondering if I should take this back and get the blue one instead?
Thanks
Wayne
Re: Correct type of anti-freeze to use
« Reply #1 on: 22 November 2007, 14:10:20 »
As long as you flush the system well the red will be fine. In fact it's far superior to the blue stuff. :y
hotel21
  • The Kingdom of Fife
« Reply #2 on: 22 November 2007, 14:14:43 »
MY2001 means model year 2001
wayneywoo
  • Hemel Hempstead
« Reply #3 on: 22 November 2007, 14:32:23 »
Thanks guys.
A good flush and red it is then.
ians
  • Reading
« Reply #4 on: 22 November 2007, 17:30:03 »
..bet it would have been cheaper to buy it at Vx... ;)
« Reply #5 on: 22 November 2007, 19:39:38 »
Vx's own Red can be mixed with blue without issue. Its pretty cheap for red as well ;)
« Reply #6 on: 22 November 2007, 21:13:14 »
That's good to know, cos it's in Emma's MX now (previously blue / green). :y
Think I flushed it pretty well though.
Best way to add it is to flush the system by your preferred method, drain as far as possible and add the correct amount for your coolant capacity neat - to give 50% concentration. Then top the system up with water.
If you pre-mix it you'll find there is always some water in there so you can't 100% fill it with the mixture and it'll end up too weak.
wayneywoo
  • Hemel Hempstead
« Reply #7 on: 22 November 2007, 22:40:53 »
So take the red back to Halfrauds and get red from Vauxhall?  Is it cheaper from Vauxhall dealer or are we talking vauxspares?
Thanks!
« Reply #8 on: 22 November 2007, 22:51:31 »
I wouldn't worry too much now. For future reference the vauxhall dealers sell red coolant at a reasonable price, especially on trade club.
It will probably say if it's not compatible with other types of coolant but if you fill the system with clean water, run for a few minutes then drain, and repeat this process a couple of times it will have removed all significant traces of the old coolant anyway. Do this with the heater on maximum heat.
« Reply #9 on: 23 November 2007, 09:09:53 »
Some reds either congeal with traces of blue, or turn slightly corrosive to the seals.
Vx red is about £10 retail from dealer for 5l
« Reply #10 on: 23 November 2007, 09:48:02 »
£9.70+Vat retail for 5 litres.....£7.32+Vat trade club
