Author Topic: Heavy Steering  (Read 3378 times)
Heavy Steering
« on: 19 November 2007, 23:19:24 »
1998 Elite 2.5V6 Estate Auto.
Further to my recent post re dodgy ABS ECU, http://www.omegaowners.com/forum/YaBB.pl?num=1194380670/10#0      , have noticed that whilst ABS & TC lights on and no speedo, steering appears heavier than normal.  When warning lights go off & speedo working, steering seems to return to normal.
Is this coincidental, or a function of the dodgy ECU?
Aux belt OK, power steering fluid level ok, power steering pump quiet.
Will be swapping ECU later this week so hopefully will sort out steering - or do u know otherwise????
« Last Edit: 19 November 2007, 23:21:20 by dbug »
Re: Heavy Steering
« Reply #1 on: 19 November 2007, 23:26:00 »
Those are EXACTLY the symptoms I had when my ABS ECU failed. BBA Reman repaired it and since refitting in August I've had no problems ... didn't need re-programming either as it was the original part :)
Re: Heavy Steering
« Reply #2 on: 19 November 2007, 23:31:40 »
Including heavy steering?
Have 2nd hand ECU off same model, engine size & year to fit so shouldn't need reprogging.
Re: Heavy Steering
« Reply #3 on: 20 November 2007, 11:39:32 »
Yup .. its my understanding that the speed signal the steering needs to change the "assist" level comes from the ABS sensors, via the ABS ECU .. probably wrong but that was the info I was given when mine failed..  :(
Re: Heavy Steering
« Reply #4 on: 20 November 2007, 19:24:18 »
Thanx 4 that.
Re: Heavy Steering
« Reply #5 on: 20 November 2007, 19:41:19 »
Yes, all 6 cylinder Omegas have speed sensitive steering, that relies on the speed signal from ABS for proper operation.
Jay w
  • Plymouth/Poole
  • omega gone
Re: Heavy Steering
« Reply #6 on: 20 November 2007, 22:43:15 »
i wouldn't take that for granted, you could still find that it will need a session on Tech2
Re: Heavy Steering
« Reply #7 on: 20 November 2007, 23:18:21 »
As a minimum, it needs to have the same (or superceeded) Ident code (2 letter code)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Heavy Steering
« Reply #8 on: 21 November 2007, 08:25:52 »
Does that include TD's (BMW)??
IW
Re: Heavy Steering
« Reply #9 on: 21 November 2007, 13:47:50 »
IW
yup. ALL 6 cylinder Omegas ;)
Pitchfork
Re: Heavy Steering
« Reply #10 on: 21 November 2007, 17:34:51 »
So, there is an advantage to owning a Tractor after all!! :P
Re: Heavy Steering
« Reply #11 on: 21 November 2007, 18:17:34 »
Why? All 6 cylinder Omegas have it. And 2.0/2.2 aren't proper Omegas so don't count :P
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Heavy Steering
« Reply #12 on: 21 November 2007, 20:08:41 »
Watch it sunshine >:(
I like red cars
davlad22
  • Sunny Yorkshire
Re: Heavy Steering
« Reply #13 on: 23 November 2007, 02:27:56 »
Behave! 4 cyl DTi Elite has it as well.
Re: Heavy Steering
« Reply #14 on: 23 November 2007, 09:06:49 »
Really? didn't think the DTis had it?
