Pages: 1 [2] 3  All   Go Down
Author Topic: 3 ltr V6 elite problem.  (Read 6180 times)
Re: 3 ltr V6 elite problem.
« Reply #15 on: 02 November 2007, 14:46:35 »
still playing up....
the bits i have changed have made it better but not 100% right...
missfires around 2.5k...cuts out and does not like starting when its hot or cold at times...get it to catch and wind the revs up to the limiter some times cures it or it will do this 3-4 times..then booting it will clear...
did it today and managed to get some fault codes in a strange order...
flashing 12 (ok) do that 2-3 times then (13 and then 5? if i picked the revs up to the problem area of 1-2.5k while missfiring/lumpy) again 2-3 times and ...deffinate gap between the 13 and the 5 though! as the revs went back to tick over back to 12 only... :-?
moved trapped wires on co2 sensor but not tested, as cleared again now! ::)
so if any one wants a challenge or is bored you can work that one out for me :)
off drag racing this weekend with the van on tow....well thats if it makes it!...so look back in next week..
also mpg does seem to drop at times...but then i guess it would.
cheers mark...
assuming the changed crank sensor is ok, cam sensor is left..Not sure though..
edit : think also throttle postion sensor is another candidate..
better trusting the codes for replacement
« Last Edit: 02 November 2007, 15:06:01 by cem_devecioglu »
saintnick
  • Portsmouth Hampshire
« Reply #16 on: 04 November 2007, 10:40:28 »
try unplugging the crank sensor and plugging it back in again, sounds daft i know but mine was cutting out as yours was and i tried it all, ICV, leads plugs dis pack( they were bieng replaced anyway) i took the crank plug, disconnected it plugged it back in and no more probs.
not sure why but there you go.
If It aint broke....Lets just dismantle it anyway!
pops
  • reading
« Reply #17 on: 05 November 2007, 06:30:57 »
well it managed a 200 mile round trip, but not happy..
could feel it missfiring and trying to cut out....lost a lot off pull..i.e. very flat...
the only thing i sort of found was when it start to die around 3k if you planted your foot down it would recover for another 20 mins or so....
at one time it would not pull at all....as floored it..and did not want to pick up at all...
and on the last 20 mins of a 2 hour run on the a/b roads had to put it in sports mode to get any pull...overall 15mpg with a 2 berth caravan... at 50 to 60 mph....
then on the way back at times if was fine after cutting out at a r/about and trying to die about 10 times... so it might have to go into the garage.....
anyone know of any good garages around the reading area?....
tnx mark...
ians
  • Reading
« Reply #18 on: 05 November 2007, 12:31:22 »
Mark,
I'm in Reading, but TBH other than moral support not sure what I could add.   I'm assuming that all the usual filters (air, fuel) are in good nick,  HT leads, plugs checked etc?
You might try giving DK Cars in Thatcham a call and asking for service.   The chap there knows Omegas well and may be able to help.   rates are decent too.
Cheers
Ian
« Reply #19 on: 05 November 2007, 16:04:16 »
Fuel filter worth checking (and changing if older than 2yrs), along with air filter.
Actual misfires, with no codes are often HT, so recheck plugs/leads/dis and ensure no oil in plug wells.
Lack of power - cam timing and/or multirams
pops
  • reading
« Reply #20 on: 05 November 2007, 21:14:53 »
tnx guys for all the info and help...gona change the fuel filter next...
BUT... might have found it...phoned a mate who has an omega..so we took the plugs out and yes..the r/hand bank has a rocker cover leak, which he had the same problem...the amount of oil in the plug wells was impressive all three where swimming in it...and of course it had to be the worst side to get at ::)
so it might seem like some of you guys got it... as now i dont trust it, we will see what happens over the next few weeks, i would say days but its caught me out before now a few times... :(
again many tnx to all for your help :y
will report back again in the future..
many tnx mark
« Reply #21 on: 05 November 2007, 21:18:00 »
good luck :y
« Reply #22 on: 05 November 2007, 22:19:31 »
Mark,
Cheers
Ian
DK Cars still going then ?? Thats who we bought the meega from in Aug 2002 !
Must admit they gave us excellent service, fixed a few minor problems in the first 6 months without a single hitch, and the car has been damned good ever since .. :)
ians
  • Reading
« Reply #23 on: 06 November 2007, 10:51:41 »
Yes they are still there.   No Omega's in their last ad in the local paper though.
Friednly and helpful lot I agree.
pops
  • reading
« Reply #24 on: 08 November 2007, 10:51:57 »
well it was better for a short while......
then worse!....i guess there must have been a sort of semi seal formed around the ht caps..which now is letting the oil in more....
so its now stripped out...only took an hour, i am impressed with myself there!....r/h bank i.e. 2-4-6 oiled again... interesting though it looks like it been apart and all cleaned up...so maybe cheap gaskets?...
while try to get to work this morning, it was trying it best to cut out, really misfiring so in the intrest of clearing it (auto box)i put it in 1st and floored it up to the red line then into second and off and..had a clear warning light..checked and code 74 ...i am gueesing here that with the r/h bank not being right and under the conditions this could be a bogus reading?..not a problem if not as about the easiest sensor to get at...lol....
now gona phone and track down parts and a lift to get them.... 50/50 weather to do the l/h bank even tough its not leaking...dificult as a firm beliver of if its not broke then dont fix it!!!!!give it a miss until next time????    ::)
cul mark :)
pops
  • reading
« Reply #25 on: 08 November 2007, 13:48:27 »
dam nearly got caught out at the local vauxhall dealers :o
asked for a cam cover gasket, to which the reply was they dont do one you have to buy the complete cam cover at 80+ quid! the polite reply was your joking but it was not what i was thinking ::)...but it was lucky as nil stock...
nipped into reading...asked if they did a cam cover gasket and yes sir we do at £26 but out of stock....so all parts should be in on saturday with a bit of luck...
dam near temped to phone the other one back >:( but dont think its worth waisting the energy....
dogey old game at times...
cheers mark
« Reply #26 on: 08 November 2007, 13:50:41 »
Thast why I included the part numbers in the maintenance guide.
pops
  • reading
« Reply #27 on: 19 November 2007, 17:05:14 »
still fighting with this one...
it loads better but...last week when the fuel was low it did not want to start..just whizzing over...like no fuel...switched it of and tried again and it slowly started.....done the nor..i.e. gave it a big rev up...cleared again...
tonight was running nicely....
so thought lets see what it pulls like in sports mode....pulling very strong....take sports mode off coasted up to juction..revs dip to 500...then thats it cutting out again....if i keep the revs over 1500 i can get going again...cuts out 3/4 times..so red lines it as getting anoyed now...problem cleared again until tomorrow i guess....
so far....
new fuel filter..fuel pump relay...air filter..cam gaskets...plugs...cam/knock sensor (near oil filter)...icv flushed/cleaned with carb cleaner...
defo seem more fuel related now or complete loss of spark...?????
doing my head in now....much more and its going...
any ideas????
tnx mark..
« Last Edit: 20 November 2007, 06:12:15 by pops »
pops
  • reading
« Reply #28 on: 20 November 2007, 17:16:18 »
now getting fault code 74 ..air flow sensor...
runs fine uless i give it some then as you slow down you can feel it getting lumpy and it will cut out if the revs drop to low...if you can be gentle with it then it will recover until the next time you take it up to 4k revs...even take it up to 4k in the drive and it will cut out when you take your foot off..but the engine warning light is not coming on apart from when its stopped...
is it also know as the maf?...which vauxhall want over 300 for???....
or can i get one some where else?....
tnx mark
« Last Edit: 20 November 2007, 17:21:03 by pops »
« Reply #29 on: 20 November 2007, 17:30:20 »
Classic air leak symptoms.....
Pages: 1 [2] 3  All   Go Up
Page created in 0.027 seconds with 21 queries.
