Author Topic: Rear windows not working  (Read 3848 times)
garbage456
  • Carshalton, Surrey
« on: 24 November 2007, 10:08:51 »
hi,
The rear windows are not working I have moved the swtich on the drivers doot from red to green but still they are not working.
BUT
I can control them from my door.
Any ideas please?
Dave-C
  • Staffordshire
  • The Old Girl
Re: Rear windows not working
« Reply #1 on: 24 November 2007, 14:00:59 »
Is the amber light on, on the switches on the rear door?  if not either the disable switch is u/s or a fuse...  but, I think the fuse does all windows!!!!!
DC
What year is your Meega???
« Last Edit: 24 November 2007, 14:02:50 by dave_c »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 24 November 2007, 14:26:01 »
Hada similar thing with the rangey once turned out to be a broken wire where it goes into the door :y
garbage456
« Reply #3 on: 24 November 2007, 16:11:17 »
hi just got back in
its a jan 2001
garbage456
« Reply #4 on: 24 November 2007, 16:12:00 »
DC
hi
not sure they even have amber lights i will go out and check
garbage456
« Reply #5 on: 24 November 2007, 16:14:33 »
do you mean the light that shows up under the picture of a window on the switch that comes on when you turn the head lights on?
If yes then yes
« Reply #6 on: 24 November 2007, 18:18:52 »
DC
According to Haynes wich obviously only goes up to face lift .....
Front woindows Fuse 1
Rear windows   Fuse 7
garbage456
« Reply #7 on: 24 November 2007, 18:23:43 »
thanks for that
The drivers door can still control the windows at the back though so could it still be a fuse?
« Last Edit: 24 November 2007, 18:24:01 by garbage456 »
« Reply #8 on: 24 November 2007, 18:47:02 »
thanks for that
Ah? I should have read the original question!  :-[
Sounds more like it could the rear switches at fault ..... although you'be be unlucky for both to have failed at the same time, or probably more likely to be the inhibit switch that's failed.
AIMHO  ;)
« Reply #9 on: 24 November 2007, 19:21:48 »
The Amber LED on the REAR window switches on the REAR door. Are they on.
garbage456
« Reply #10 on: 24 November 2007, 21:55:51 »
hi there arent LED's I cant even see a bulb an LED are you sure they are on Omega Elite 2001 3.0?
« Last Edit: 24 November 2007, 21:56:07 by garbage456 »
garbage456
« Reply #11 on: 24 November 2007, 21:56:43 »
thanks for that
AIMHO  ;)
Yeah I think the switch has failed on the drivers door more likely.
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #12 on: 25 November 2007, 08:33:46 »
Not sure if there are LED's on the Meega's after 99/00.....   I assumed your car was earlier initially....  perhaps someone with a newer car can help....................  I'd check the fuses first however....   DC
« Reply #13 on: 25 November 2007, 09:50:54 »
The windows do work but only from the front so the fuses are OK.
Hemppa
  • Finland
« Reply #14 on: 25 November 2007, 11:19:28 »
I had exactly same problem, and reason was faulty "red/green switch".
I fixed it myself, with a piece of electrical tape inside the switch...
