Author Topic: Bonnet Release  (Read 1620 times)
cbs2
  • East Kilbride
  • Right....Fire Up The Quattro!!!
Bonnet Release
« on: 24 November 2007, 15:15:46 »
Does anybody know how to adjust a lazy bonnet release? Had a look in haynes but it only shows the removal.
I think I may have 2 problems.
The bonnet release doesn't work every time
And the release spring doesn't pop the bonnet up
Thanks
Colin
Taking part in the 2010 sucata split charity banger run. www.sucatasplit.com
www.boozebrothers2010.co.uk
Ex-mig owner................For now
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: Bonnet Release
« Reply #1 on: 24 November 2007, 15:33:07 »
It's easier to do than to explain. The cable is held in by some clips and it eventually slips. You just need to losen the clips and pull the outer sheath towards the catch by a few millimetres. Tighten the clips again and the job's done.  :y
[size=24]        [/size][/b]
ghondie
  • sheerness,kent,uk
  • Looking for work, any offers?
Re: Bonnet Release
« Reply #2 on: 24 November 2007, 16:10:22 »
Thanks
Colin
hi yeah i have the same problem, it does pop every time but not to its fll extent, and i have to lift it up slightly each time before i operate the lever. will try the solution offered and see what happens.
cheers
Man with a mission. not sure what it is but i've got one
Sheerness Lifeboat Crew and ILB Mechanic
Re: Bonnet Release
« Reply #3 on: 24 November 2007, 19:26:06 »
and the said clamp is under the plastic trim just in front of battery
cbs2
  • East Kilbride
Re: Bonnet Release
« Reply #4 on: 25 November 2007, 10:12:18 »
Thanks guys
going to give it a go
miggy
Re: Bonnet Release
« Reply #5 on: 25 November 2007, 18:12:14 »
Thanks
Colin
This can be adjusted at the spring if the bonnet does not pop, slight adjustment may be needed using a spanner at the base of the spring. if your cable is secure i would check the spring.
« Last Edit: 25 November 2007, 18:13:19 by miggy »
