Author Topic: ar 35 ratios for td  (Read 3859 times)
osealy
  • dublin
Re: ar 35 ratios for td
« Reply #15 on: 24 November 2007, 22:41:10 »
Thanks for that. Now I'll see if i can bribe someone to do it for me. I'm a bit past slideing around on my back . Also I tend to loose dropped bolts in the gravel.
« Reply #16 on: 26 November 2007, 09:54:13 »
Do you know what diff ratio is in the tractor, Jaime?
Just wondering if you could swap it for a shorter geared one?
was thinking similar myself...
I think you'd still have a "hole", as that's down to the step between the ratios, but with lower overall gearing it might pull through it better.
