Author Topic: Engine Cuts Out  (Read 4918 times)
dazzie
Engine Cuts Out
« on: 21 November 2007, 18:54:43 »
Hi guys, Gr8 site
The problem I have.
When driving my car for a little while, it will cut out but will start straight away and th EML comes on and will not cut out again. I did the paperclip test and gave me codes of 0100-Mass Airflow Sensor, 0335-Crank Sensor, 0340-Camshaft Sensor.
I don't know if the codes were ever reset before I got them.
Can anyone please help.
Thanks Daz.
Grumpy
  • Manchester
Re: Engine Cuts Out
« Reply #1 on: 21 November 2007, 19:15:42 »
Hi, Dazzie, and welcome to the site.
Judging by your codes, I guess you have a 2.0L ?
If so, first check your Breather System and fix as required iaw
this link. It's a very common problem on 2.0L's.
http://www.omegaowners.com/forum/YaBB.pl?num=1194007453
Out of your codes, the one I would be worried about is the Crank Sensor.
I would change this.
The other codes may be being brought on by your stalling, or air leaks
for the MAF.
When you've done the breathers, see if you are rev limiting (if you're
still getting the EML light on), which will tell you if the crank or cam sensor
codes are likely to be genuine.
Report back with results or any questions. Wealth of experience on this site
for your problem.
Re: Engine Cuts Out
« Reply #2 on: 21 November 2007, 20:25:20 »
The 2.0l will not flash out the cam and crank once fixed.  Look at replacing these. Cam sensor is easy, but the crank is a pig if you have A/C
dazzie
Re: Engine Cuts Out
« Reply #3 on: 22 November 2007, 10:24:52 »
Hi WOW fast reply.
Thanks guys I will try this at weekend. I forgot to say my car is a 2.0L 16V Auto. Can be a little thirsty gat about 22mpg. Can this be improved on.
dazzie
Re: Engine Cuts Out
« Reply #4 on: 23 November 2007, 08:22:41 »
Hi guys, Sorry to be a pest. Can anyone tell me where the crank sensor is, I cannot find it in the haynes manual.
Thanks.
Re: Engine Cuts Out
« Reply #5 on: 23 November 2007, 09:04:11 »
behind a/c compressor, front left of engine
brett1408
  • leamington spa
Re: Engine Cuts Out
« Reply #6 on: 24 November 2007, 12:39:19 »
hi having fun with the crank sensor change!!! they're worse on vectra's! 22mpg dont sound too bad, my 3.0 elite's re-mapped and i get 15, 16 mpg at best!
speakingclock
  • North Wales
Re: Engine Cuts Out
« Reply #7 on: 24 November 2007, 20:21:00 »
22mpg seems a bit too low, I would be expecting nearer 30, maybe more on a run.  May be worth recalculating afetr the breather clean and sensor renewal.
Good luck :o
LPG Open Mixer System Tow Bar Mini Spots
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Engine Cuts Out
« Reply #8 on: 25 November 2007, 12:59:07 »
Off topic replies have been moved to [link=http://www.omegaowners.com/forum/YaBB.pl?num=1195995548]This Thread[/link]
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Engine Cuts Out
« Reply #9 on: 25 November 2007, 21:23:10 »
Hi, thanks for all your advice. Im gonna change crank sensor on monday, are there any images or tips on where and how to do it,
Many thanks in advance for any extra help
I like red cars
dazzie
Re: Engine Cuts Out
« Reply #10 on: 26 November 2007, 10:00:21 »
Hi Everyone, Today is crank sensor day, The location is it battery side or airfilter side.
Many thanks in advance.
Re: Engine Cuts Out
« Reply #11 on: 26 November 2007, 10:30:44 »
Battery side....
dazzie
Re: Engine Cuts Out
« Reply #12 on: 26 November 2007, 14:12:43 »
Hi, I didn't do crank sensor, I couldn't find it,  Images, diagrams and instructions would be a gr8 help.
Thanks.
Grumpy
  • Manchester
Re: Engine Cuts Out
« Reply #13 on: 26 November 2007, 14:59:53 »
You can't see it, Dazzie.
Put your hand on the oil dipstick tube. Run your hand down until you
meet the crankcase. Feel forward, towards the front of the engine,
approx 2". You will feel the sensor.
Several of us have changed it using different methods.
I removed the heat shield from the exhaust manifold and changed
it by touch.
Vectrolysis removed the LH engine mount and did it from underneath.
TaxiDriver had his changed by removing the oil dipstick tube and changing
it from the top, same as me.
When I next have to do mine again, I will do it the same way but will
remove the oil dipstick tube to improve access.
« Last Edit: 26 November 2007, 15:00:41 by Grumpy »
dazzie
Re: Engine Cuts Out
« Reply #14 on: 26 November 2007, 15:41:10 »
hi guys, Thats why I couldn't see it, Thanks very much.
Just 1 more question, Where is the plug end.
Thanks for all your super help.
