Author Topic: Very Strange ECU related problem...  (Read 1454 times)
pankoboy
  • Spalding, Lincolnshire
  • If your not first.... your last!
« on: 22 November 2007, 11:58:41 »
Hi guys. a few weeks ago i went to start her up and the she just wouldnt fire. opened up the bonnet and heard a solenoid/relay click. after a while i gave it a technical tap... sure enough started ok, and was fine for a few days. its now doing it more regularly and even cut out when driving the other day.
So a friend and I armed with a screwdriver and test light attacked the fuses and relays, no fault found. thinking it was a dodgy relay i began to tap them all. nothing. It wasnt until i caught the ecu with my arm that it cut out! appears that if i move the ecu up or down (started or not) it causes what i will assume to be a lack of spark/fuel... Now the ecu has been chipped, do you guys think it could be the chip or the whole ecu?
any thoughts would be appreciated
Thanks
Matt
PS I have checked as much of the wiring as poss, and cant see any obvious faults..
www.track-attack.co.uk - The Motorsports enthusiasts forum.
Re: Very Strange ECU related problem...
« Reply #1 on: 22 November 2007, 19:47:03 »
Check the chip is fully seated - being socketed, it may have started to creep out.
Also, and this may sound really daft, can you measure the battery voltage before and during cranking?
pankoboy
« Reply #2 on: 26 November 2007, 22:15:53 »
Hi there, thanks for your reply, i have put the old chip back in which does seem to fit much more snug and all my problems have gone, the abs/ecu light doesnt come on, starts first time, going to take the chip back and complain! Thanks for your reply!
