Author Topic: Adjusting Headlights???  (Read 1948 times)
chuck_g
  • Cork, Ireland
« on: 27 November 2007, 17:36:30 »
How do i adjust my headlights on a 95 omega? Anybody have a diagram?? Thanks!!!
O.M.E.G.A -Opel make extra great automobiles
http://www.chucklez84.bebo.com
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Adjusting Headlights???
« Reply #1 on: 27 November 2007, 20:24:34 »
On top of the headlights are two white adjusters. you will need an allen key to move the adjusters to the correct alignment/height :y
« Last Edit: 27 November 2007, 20:25:20 by ffcgary1 »
Jaguar XJ6
chuck_g
  • Cork, Ireland
« Reply #2 on: 27 November 2007, 23:27:28 »
Tried that it doesnt seem to work!!!  :(
ffcgary1
  • Mitcham,Surrey.
« Reply #3 on: 27 November 2007, 23:39:19 »
If that has not worked, do they adjust on the motors controlled by the adjuster by the head light switch. if they do then the manual adjusters are broken. Remove the headlight and shake, if you can hear a rattle then they have broken up and you need new headlighhts.
Jaguar XJ6
chuck_g
  • Cork, Ireland
« Reply #4 on: 28 November 2007, 00:17:47 »
Will do thanks lad!!!! Now back to seseme street u go .................. ;D
« Reply #5 on: 28 November 2007, 08:37:44 »
NO....dont turn the white adjuster.....look at the front of the llight assembly and you will see a metal bolt type assembly, its this you need to turn and it does take quite a few turns.
