Author Topic: Auto gearbox - Kettering area  (Read 2204 times)
mickeydeane
  • Northamptonshire
« on: 26 November 2007, 09:52:16 »
Hi
I am having problems with autobox on my omega - can anyone recommend a mechanic/garage in the Kettering/wellingborough area who would be able to correctly diagnose and sort out the problem - it sounds like its the gear selector switch (sticks in 3rd when in drive)
cheers
bogit
  • Northampton
  • yes i do know its missing 2 wheels :)
Re: Auto gearbox - Kettering area
« Reply #1 on: 26 November 2007, 09:54:01 »
the only local one is in wellingborough. cant remember the name of the top of my head, or a trip down to luton. :-/
dash bulbs replaced,ecc sorted,atf to go, door blowers-maybe
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #2 on: 26 November 2007, 10:24:08 »
Hi
I used to use an auto specialist guy in Littlethorpe for auto box oil and filter changes before I moved. Can't remember the name but its not too far from you really. Come off the M1 at Fosse Park, head for Narborough, turn right across the railway and the place is in Littlethorpe old village on the right.
have you tried changing the oil and filter to see if that improves things? There is plenty of info on here on how to do it and where to get the gaskets and filter (approx £38 in total) plus the Dexron 111 oil.
varche
arthill
  • Greenock
  • HI all pleased to join Forum
« Reply #3 on: 26 November 2007, 19:35:14 »
What are the symptoms with gearbox? selector switch is quite easily fitted by any comprtent mechanic, best getting second hand, new quite expensive. Been down that road recently myself.
  John
John
arthill
  • Greenock
« Reply #4 on: 26 November 2007, 21:19:31 »
HI.
Got your message, Switch cost me £79 got it through Patrs Gateway got next day delivery but shop around probably get it cheaper, Dealer wanted £235 but I beleive same switch may be fitted to other cars also according to posts read on this form. Someone else may be able to advise you on this, hope this helps.
   John
« Last Edit: 26 November 2007, 21:21:22 by arthill »
John
« Reply #5 on: 26 November 2007, 22:02:55 »
Sticking in 3rd just means its in limp, and may or may not be selector switch
bogit
  • Northampton
« Reply #6 on: 27 November 2007, 22:22:46 »
i lied, there in kettering not wellingborough, can you tell im not from round here rearly  :-/
on the industrial estate round the back of the hospital.
Henson way , garrard way , round there somewhere.
mkaminski100
  • Basingstoke
« Reply #7 on: 27 November 2007, 22:59:32 »
I have called two garages fixing gearboxes, and was told that it cost ca 1000 pounds + VAT to fix any gearbox! Do you know any other garage/shop around Reading (radius 50-70 miles) where I can buy a second hand gearbox or fix mine?
mickeydeane
  • Northamptonshire
« Reply #8 on: 28 November 2007, 14:42:51 »
Many thanks to all for replies - much appreciated.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #9 on: 28 November 2007, 15:35:58 »
Try Allens Garage in Tadley (that's only 12 miles or so from you) & ask for Gareth
See a similar thread on this page
MutantCav
  • Gainsborough
« Reply #10 on: 28 November 2007, 15:39:25 »
If you want a second hand selector switch I can send you the one off the car I'm stripping, M reg 2.5 like yours and gearbox is smooth...£45 including postage :)
