Author Topic: back pressure in rocker cover.  (Read 1160 times)
TIN-V6
  • west sussex
« on: 29 November 2007, 20:53:47 »
hi all,
help please???,i have just found while checking the oil and filler neck for mayo,and there was a fair amoumt.
just after turning the engine off that when you remove the oil filler cap there is a presure build up i guess this is due to the oil breather being blocked or is there somthing else it could be?,
also could any body tell me where thay are?
sorry for being a pain.many thanks.
tony(tin-v6)  .... [smiley=beer.gif]  [smiley=dankk2.gif]
        THANKS TO ALL WHO  REPLYED.....will clean them tomorow.........
« Last Edit: 29 November 2007, 21:49:30 by TIN-V6 »
Re: back pressure in rocker cover.
« Reply #1 on: 29 November 2007, 20:56:59 »
Sounds like the breathers are totally blocked to me. Have a look in the howto section for details. It needs to be done ASAP before the cam cover gaskets fail.
hotel21
  • The Kingdom of Fife
« Reply #2 on: 29 November 2007, 20:57:14 »
Howdoo Tony.  certainly sounds like blocked breathers.    Take the time to search the various FAQ's and howtoo's on the site, your answers are all there, waiting for discovery!!   :y
Not a hard job to do, budget an easy hour and a couple of cans of carb leaner.....   ;)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 29 November 2007, 21:23:59 »
the Mayo in your filler cap mate can be caused by cheap oil. Fit a new filter, and new oil Vauxhall's own is very good and not to dear either..
This is your breather Body behind the drivers side Cam Cover, a small hole that a pin or needle will clear, the other is bigger (i used a screwdriver). If your using Carb Cleaner when cleaning out the Breather Body, Change your oil after
« Reply #4 on: 30 November 2007, 08:48:51 »
Full details with pictures on how to do this job here:
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
