Author Topic: Omega Elite 1997 ECU...  (Read 3593 times)
oredona
  • chatham, Kent
« on: 26 November 2007, 22:08:28 »
Hi everybody, can some one tell me which pin i have to use when checking for ECU Codes, i mean, some say A and B some say 5 and 6....
Which is correct and where  does it start numbering from?...
Sencondly , i changed my Car stereo and my speakers won'r work, i head it has a Phillip sound prcesor but i don't know which cable is which....can someone tell me what cables are used?
Picture or diatgram would be helpful as well.
thanx
Re: Omega Elite 1997 ECU...
« Reply #1 on: 26 November 2007, 22:11:20 »
Welcome :)
Look in Maintenence Guides for 'Paperclip Test' :y
oredona
  • chatham, Kent
« Reply #2 on: 26 November 2007, 22:58:40 »
Thanks, i have look into the guide, no clear information....any help would be appreciated.
thanks
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #3 on: 26 November 2007, 23:37:41 »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
oredona
  • chatham, Kent
« Reply #4 on: 29 November 2007, 17:15:08 »
I did the paper clip test, this was the result i copied.
2-1-2-1-2-5-7-5-7-5-7-1-4-5-1-4-5-1-4-5-3-1-3-1-3-1-1-2-1-2-1-2-5-7-5-7-5-7-1-4-4-1-4-5-1-4-5-3-1-3-1-3-1-2-1-2-1-1-5-7-5-6-5-7-1-4-5-1-4-5-1-4-5-3-1-3-1-3-1-1-2-1-2-1-2-5-7-5-7-5-7-1-4-5-1
Can sombedy tell me what this stands for?
Thanx
magnul
  • Trondheim, Norway
« Reply #5 on: 29 November 2007, 17:28:55 »
You missed the first blink. The codes should be:
12=initiation of diagnosis
57=Idle Speed Control Valve (ISCV) Interruption
145=Incorrect immobiliser signal received Faulty unit or break in wiring
31=Engine RPM signal (crankshaft sensor) No signal
All codes according to:
http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm#bosch
The rest of the numbers is just a repetition of the above.
oredona
  • chatham, Kent
« Reply #6 on: 29 November 2007, 19:35:32 »
Thank you for this info, actually the car was fine, i changed the Crankshaft sensor just 3 days before, some of the bulbs in the In SPEEDO TACHO CLOCKS CONSUL were bad and i changed it and it refuses to start anymore..
I have brought it out and put it back again, but no way.
So with the reading i've got so far, what is the solution, is there a possibility to reset everything to normal or what should i do?..ofcourse cheaper solution.
Thanks
hotel21
  • The Kingdom of Fife
« Reply #7 on: 29 November 2007, 21:09:30 »
20 or so clean starts with all previous faults now cleared should clear the existing codes, I think....
Also, take a few mins to update your personal profile on here so that we know where you are (nearest biggish town will do) and what car you drive.  Also nice to know if you are male or female.....     ;)
« Last Edit: 29 November 2007, 21:10:35 by hotel21 »
oredona
  • chatham, Kent
« Reply #8 on: 29 November 2007, 22:04:26 »
Thanks
i have updated my profile and regarding me starting the car 20times, i have tried several times but no way, it just keep sounding like there is no feul coming in....some say it's the immobilizer.
But shouldn't there be a way to reset everything to it's original position?
tanx
oredona
  • chatham, Kent
« Reply #9 on: 30 November 2007, 19:30:44 »
is there actually any other way i could reset the ECU, i have taken off the battery, tried to start it several times but still no luck..
Tanx
« Reply #10 on: 01 December 2007, 16:38:39 »
Is the EML flashing when you turn the ignition on?
oredona
  • chatham, Kent
« Reply #11 on: 02 December 2007, 08:19:31 »
no light is flashing, it just wouldn't start, sounding as if no fuel is coming in....a friend said probably it's the immobilizer but i don't know.
« Reply #12 on: 02 December 2007, 10:19:15 »
If it was immobiliser, the eml would flash.  The only thing sensorwise that seems to stop a v6 is crank sensor...
oredona
  • chatham, Kent
« Reply #13 on: 04 December 2007, 09:25:00 »
could it be my Crankshaft sensor?....
If it refuses to start, what are the possible causes, where i can check?
« Reply #14 on: 04 December 2007, 10:06:09 »
Did you plug the idle valve back in?
Try starting it with a little throttle....
